Use multiple recipient delimiters
Posted: 12 Sep 2020 15:27
by Mr. Happy
Currently the + is working as a delimiter, but I would like to use bot + and -.
The reason is that not every company I want a different mailaddress for supports the +.
The issue is I can't get the +- or minus to work.
With only the + it works.
With the +- it only works for +.
With the - it fails.
In the maillog it prints
Recipient address rejected: undeliverable address: No user at this address
I did restart Postfix after each time I changed the delimiter and after that I sent a testmail.
What am I missing??
Re: Use multiple recipient delimiters
Posted: 12 Sep 2020 16:50
by smyers119
Why are you messing with the recipient delimiter at the spam gateway level? That sounds like a job for the Mail Server, the spam gateway should just be passing it on as it is.
Posted: 12 Sep 2020 16:54
by Mr. Happy
smyers119 wrote: ↑12 Sep 2020 16:50
'Cause I' m also using recipient filtering at efa....
Posted: 12 Sep 2020 16:58
by smyers119
Did you check what version postfix is running. It only supports multiple delimiters in 2.11 and later
Posted: 12 Sep 2020 17:02
by Mr. Happy
smyers119 wrote: ↑12 Sep 2020 16:58
According to
I have
Posted: 12 Sep 2020 17:07
by smyers119
If that is not the problem then post the log, maybe "propagate_unmatched_extensions" is messing you up? (if its even configured) (I don't have eFa in front of me to investigate myself)
Posted: 12 Sep 2020 19:59
by Mr. Happy
smyers119 wrote: ↑12 Sep 2020 17:07
I don't know what was the matter, but I rebooted the vm and now it works fine...
Thanks..
