Problems signing outbound DKIM - Solved
gdoornenbal
Post by gdoornenbal »
First of all sorry for my long post, but with less info i think i will not find a solution for my problem..
I recently migrated successfully from efa 3 to 4. My situation is as following:
I have an internal mailserver, which is using the EFA server as outbound mail relay, and all incoming mail is also flowing through the efa to the internal mailserver. That is working correctly so far.
But now i am trying to get outbound DKIM signing to work, but until now all my efforts fails..
I followed the instructions from jamerson (viewtopic.php?t=4111)
Installing opendkim was not nessecary however.
I ended up with the following configuration:
# ls -l /etc/opendkim/keys/mydomain.org/
-rw-------. 1 opendkim opendkim 887 Aug 27 22:52 default.private
-rw-------. 1 opendkim opendkim 327 Aug 27 22:52 default.txt
# cat /etc/opendkim.conf | grep -v "#" | grep -v "^$"
PidFile /var/run/opendkim/opendkim.pid
Mode    sv
Syslog  yes
SyslogSuccess   yes
LogWhy  yes
UserID  opendkim:opendkim
Socket  inet:8891@localhost
Umask   002
SendReports     yes
SoftwareHeader  yes
Canonicalization        relaxed/relaxed
Domain  mydomain.org
MinimumKeyBits  1024
KeyTable        /etc/opendkim/KeyTable
SigningTable    refile:/etc/opendkim/SigningTable
ExternalIgnoreList      refile:/etc/opendkim/TrustedHosts
InternalHosts   refile:/etc/opendkim/TrustedHosts
OversignHeaders From
# cat /etc/opendkim/KeyTable | grep -v "#" | grep -v "^$"
default._domainkey.mydomain.org mydomain.org:default:/etc/opendkim/keys/mydomain.org/default.private
[root@efa4 admin]# cat /etc/opendkim/SigningTable | grep -v "#" | grep -v "^$"
*@mydomain.org default._domainkey.mydomain.org
# cat /etc/opendkim/TrustedHosts | grep -v "#" | grep -v "^$"
127.0.0.1
::1
192.168.1.13
internalmail.mydomain.lan
server.mydomain.org
# tail /etc/postfix/main.cf | grep -v "#" | grep -v "^$"
masquerade_domains = mydomain.org
smtpd_milters = inet:localhost:8891, inet:localhost:8893, inet:127.0.0.1:33333
non_smtpd_milters = inet:localhost:8891, inet:localhost:8893
milter_default_action = accept
qmqpd_authorized_clients = 127.0.0.1 [::1]
message_size_limit = 133169152
mailbox_size_limit = 133169152
enable_long_queue_ids = yes
error_notice_recipient = root
sender_canonical_maps = hash:/etc/postfix/sender_canonical
recipient_canonical_maps = hash:/etc/postfix/recipient_canonical
When i send an email the logging in mailog is as following:
Aug 31 21:05:50 efa4 postfix/smtpd[114559]: connect from internalmail.mydomain.lan[192.168.1.13]
Aug 31 21:05:50 efa4 postfix/smtpd[114559]: Anonymous TLS connection established from internalmail.mydomain.lan[192.168.1.13]: TLSCDHE-RSA-AES256-GCM-SHA384 (256/256 bits)
Aug 31 21:05:50 efa4 postfix/smtpd[114559]: 4BgKRL66PkzDm4: client=internalmail.mydomain.lan[192.168.1.13]
Aug 31 21:05:50 efa4 postfix/cleanup[114569]: 4BgKRL66PkzDm4: message-id=<internalmail.5f4d4a0c.262d.4dbad9ed728eba27@internalmail.doornen
Aug 31 21:05:50 efa4 opendkim[117399]: 4BgKRL66PkzDm4: internalmail.mydomain.lan [192.168.1.13] not internal
Aug 31 21:05:50 efa4 opendkim[117399]: 4BgKRL66PkzDm4: not authenticated
Aug 31 21:05:50 efa4 opendkim[117399]: 4BgKRL66PkzDm4: no signature data
Aug 31 21:05:50 efa4 opendmarc[117371]: 4BgKRL66PkzDm4: SPF(mailfrom): gerrit@mydomain.org fail
Aug 31 21:05:50 efa4 opendmarc[117371]: 4BgKRL66PkzDm4: mydomain.org none
Aug 31 21:05:51 efa4 MSMilter[114567]: MailWatch: Whitelist refresh time reached
Aug 31 21:05:51 efa4 MSMilter[114567]: MailWatch: Starting up MailWatch SQL Whitelist
Aug 31 21:05:51 efa4 MSMilter[114567]: MailWatch: Read 12 whitelist entries
Aug 31 21:05:51 efa4 MSMilter[114567]: MailWatch: Blacklist refresh time reached
Aug 31 21:05:51 efa4 MSMilter[114567]: MailWatch: Starting up MailWatch SQL Blacklist
Aug 31 21:05:51 efa4 MSMilter[114567]: MailWatch: Read 6 blacklist entries
Aug 31 21:05:51 efa4 postfix/cleanup[114569]: 4BgKRL66PkzDm4: milter-discard: END-OF-MESSAGE from internalmail.mydomain.lan[192.16iggers DISCARD action; from=<gerrit@mydomain.org> to=<G.mydomain@gmail.nl> proto=ESMTP helo=<internalmail.mydomain.lan>
Aug 31 21:05:51 efa4 postfix/smtpd[114559]: disconnect from internalmail.mydomain.lan[192.168.1.13] ehlo=2 starttls=1 mail=1 rcpt=mmands=7
Aug 31 21:05:54 efa4 MailScanner[106047]: New Batch: Scanning 1 messages, 3631 bytes
Aug 31 21:05:54 efa4 MailScanner[106047]: Virus and Content Scanning: Starting
Aug 31 21:05:55 efa4 MailScanner[106047]: <A> tag found in message 4BgKRL66PkzDm4 from gerrit@mydomain.org
Aug 31 21:05:55 efa4 MailScanner[106047]: Spam Checks: Starting
Aug 31 21:05:55 efa4 MailScanner[106047]: Expired 2 records from the SpamAssassin cache
Aug 31 21:05:55 efa4 MailScanner[106047]: MailWatch: Whitelist refresh time reached
Aug 31 21:05:55 efa4 MailScanner[106047]: MailWatch: Starting up MailWatch SQL Whitelist
Aug 31 21:05:55 efa4 MailScanner[106047]: MailWatch: Read 12 whitelist entries
Aug 31 21:05:55 efa4 MailScanner[106047]: MailWatch: Blacklist refresh time reached
Aug 31 21:05:55 efa4 MailScanner[106047]: MailWatch: Starting up MailWatch SQL Blacklist
Aug 31 21:05:55 efa4 MailScanner[106047]: MailWatch: Read 6 blacklist entries
Aug 31 21:05:58 efa4 MailScanner[106047]: Requeue: 4BgKRL66PkzDm4 to 4BgKRV1q0hz5DHL
Aug 31 21:05:58 efa4 postfix/qmqpd[114581]: connect from localhost[127.0.0.1]
Aug 31 21:05:58 efa4 postfix/qmqpd[114581]: 4BgKRV22W5zDmD: client=localhost[127.0.0.1]
Aug 31 21:05:58 efa4 opendmarc[117371]: ignoring connection from localhost
Aug 31 21:05:58 efa4 postfix/cleanup[114569]: 4BgKRV22W5zDmD: message-id=<internalmail.5f4d4a0c.262d.4dbad9ed728eba27@internalmail.doornen
Aug 31 21:05:58 efa4 opendkim[117399]: 4BgKRV22W5zDmD: no signature data
Aug 31 21:05:58 efa4 postfix/qmqpd[114581]: disconnect from localhost[127.0.0.1]
Aug 31 21:05:58 efa4 postfix/qmgr[114558]: 4BgKRV22W5zDmD: from=<gerrit@mydomain.org>, size=4003, nrcpt=1 (queue active)
Aug 31 21:05:58 efa4 MailScanner[106047]: Uninfected: Delivered 1 messages
Aug 31 21:05:58 efa4 MailScanner[106047]: Deleted 1 messages from processing-database
Aug 31 21:05:58 efa4 MailScanner[106047]: MailWatch: Logging message 4BgKRL66PkzDm4 to SQL
Aug 31 21:05:58 efa4 MailScanner[113609]: MailWatch: 4BgKRL66PkzDm4: Logged to MailWatch SQL
Aug 31 21:05:58 efa4 postfix/smtp[114584]: 4BgKRV22W5zDmD: to=<G.mydomain@gmail.nl>, relay=hades62.gmail.nl[80.113.97.199]elays=0.21/0.05/0.18/0.1, dsn=2.0.0, status=sent (250 2.0.0 07VJ5wLJ012157-07VJ5wLL012157 Message accepted for delivery)
Aug 31 21:05:58 efa4 postfix/qmgr[114558]: 4BgKRV22W5zDmD: removed
Something that triggers me: opendkim does not see the internal mailserver as internal? why? I tried some stuff, no results.
But with an eFa internal testmail it doesn't work either..
I don't know where to look anymore, anyone a clue?
smyers119
Re: Problems signing outbound DKIM
Post by smyers119 »
Try adding the internal IP of the eFa aka 192.168.1.x to TrustedHosts
gdoornenbal
Tried that, but still no DKIM-Signature..
Comment out Domain in /etc/opendkim.conf. It is probably overriding your signing table.
gdoornenbal
Grrr... what also helps:
systemctl restart opendkim ; systemctl enable opendkim ; systemctl restart postfix
instead of:
systemctl start opendkim ; systemctl enable opendkim ; systemctl restart postfix
* Adding eFa server ip to the TrustedHosts was the solution.
* I added the internal mailserver (not the eFa) to trustedhosts; but that resulted in double DKIM signatures in the header. So don't do that.
* Commenting out 'Domain' in opendkim.conf was not necessary.
My current TrustedHosts:
127.0.0.1
::1
192.168.1.15
server.mydomain.org
Thanks for everybody's help, its working now! ;)
