I use Exchange server internal, and setup to use EFA ( v.4 ) as Outbound mail relay.
If I send from my Pri Domain it works fine, but if I send from my Sec. Domain it got stuck in quarantine.
If I release it manualy i got it.
in 7) 1) Outbound mail relay I have my 2 ip adress space :
1) Hosts: 192.168.99.0/24 192.168.6.0/24
in 7) 2) Outbound smart host it DISABLE
All incoming mails working fine for all domains
Please help me to sort this out
Send Emails stuck i Quarantine
Re: Send Emails stuck i Quarantine
I can see in the Gui that it's stuck in Milter Outbound Queues.
Whare are your settings for
7) Mail Settings
7) Mail Settings
I Just found out what the problem was. So problem solved.
I have resently set my system up for DMARC - DKIM etc. and something whent wrong for my second domain ( did I test it correct ? )
So alle the mails godt stuck because of that. Damn
Everything looks fine, but deep down in the logs I could see that it could not find the dkim foulder for that domain etc. ( wrong security setting :-/ )
I deleted the dkim - dmarc settings and WOLA Everything was working again
My BAD
My BAD
