Debug messages define('DEBUG', false);
yep0213
Post by yep0213 »
conf.php
// Debug messages
Does anyone know about the debug function
define('DEBUG', true);
If there is a problem, is it possible to use define('DEBUG', true) to open the debug log function, this function can record those logs, and at the same time where the logs are saved
Re: Debug messages define('DEBUG', false);
if you search for DEBUG in the /var/www/html/mailscanner/*.php, you'll find that DEBUG is just a flag that causes additional output to be added to the html.
If you look at those statements, you'll see reference to the function debug() function in functions.php. Apparently it'll output the debug information as html comments inside the webpage itself.
I've not tested it to confirm.
I normally use the error_log function and then just watch the php error log for my instance.
