efa root password
Posted: 13 Feb 2020 13:36
by bas60
I installed eFA 4 from ISO on a physical
Run the Configuration
Can't login to the box as ROOT !
tried password I originally set and when installing
Tried my user password and cli password
I can access efa via web interface
Authentication failed when trying to login as root!
Re: efa root password
Posted: 13 Feb 2020 14:14
root login is disabled. You need to login with the cli user/pwd created during setup
1. did you complete the install and rebooted?
2. How do you try to login, local or via ssh? why-> viewtopic.php?t=3415
Posted: 13 Feb 2020 16:16
by bas60
Got it thanks
