How to Setup DomainKeys (DKIM) with Postfix on EFA 4
Posted: 25 Jan 2020 22:33
DKIM (DomainKeys Identified Mail) is a method of signing electronic emails using public-private key. DKIM is used by receiving mail server for identifying email, that they are sent by authorized mail servers. It also minimizes the possibility of getting emails SPAM.
This tutorial will provide you a quick and easy way to set up DomainKeys with your POSTFIX running on EFA V 4.XX
How DKIM Works ?
When we configured DKIM on sending servers. First, we generated a public/private key pair for signing outgoing messages. The public key is configured as TXT record on a domains name server, and the private key is configured in the outbound email server. When an email is sent by an authorized user of the email server, the server uses the stored private key to generate a digital signature of the message, which is inserted in the message as a header, and the email is sent as normal.
Step 1 – Install DKIM-milter
install opendkim
Step 2 – Generate Key Pair
Now create DKIM key pair using dkim-genkey command line utility provided by dkim-milter package. For this tutorial we are using domain name “example.com”, Change this name with your actual names.
Above command will generate two files default.private and default.txt. You can created multiple DKIM keys for different-2 domains and configure with your postfix server.
Now set the proper permissions on Keys directory.
note: this is very important otherwise your efa would error out " permission denied: to load the private key
Step 3 – Configure OpenDKIM
Edit the Opendkim configuration file and Add/Update following entries in file. i like nano
Then edit the domain keys lists setting file /etc/opendkim/KeyTable and add following entry.
After that edit /etc/opendkim/SigningTable file and update following entry.
And edit /etc/opendkim/TrustedHosts file and update following entry.
10.10.20.3 is the efa internal ip
Step 4 – Configure Postfix
Now edit POSTFIX configuration file /etc/postfix/main.cf and add following values at the end of file
start opendkim and restart postfix
Step 5 – Configure DNS Entry
After configuring private key in postfix server. there will be another file generated by opendkim-genkey. Edit your DNS zone file and add this as TXT record found in default.txt. In my case this is like below.
To verify that DKIM is working properly. Let’s send a test email through command line
In the received email in our mailbox, open the source of the email and search for "DKIM-Signature". You will find something like below
or try mail tester which is quick.
if you have any questions let us know.
How DKIM Works ?
install opendkim
yum install postfix opendkimNow create DKIM key pair using dkim-genkey command line utility provided by dkim-milter package. For this tutorial we are using domain name “example.com”, Change this name with your actual names.
MYDOMAIN=example.com
mkdir -p /etc/opendkim/keys/$MYDOMAIN
cd /etc/opendkim/keys/$MYDOMAIN
opendkim-genkey -r -d $MYDOMAINNow set the proper permissions on Keys directory.
chown -R opendkim:opendkim /etc/opendkim
chmod go-rw /etc/opendkim/keysEdit the Opendkim configuration file and Add/Update following entries in file. i like nano
nano /etc/opendkim.confCode: Select all
Mode sv
Socket inet:8891@localhost
Domain example.com
#KeyFile /etc/opendkim/keys/default.private ### comment this line
KeyTable /etc/opendkim/KeyTable
SigningTable refile:/etc/opendkim/SigningTable
ExternalIgnoreList refile:/etc/opendkim/TrustedHosts
InternalHosts refile:/etc/opendkim/TrustedHostsCode: Select all
nano /etc/opendkim/KeyTableCode: Select all
default._domainkey.example.com example.com:default:/etc/opendkim/keys/example.com/default.privateCode: Select all
nano /etc/opendkim/SigningTableCode: Select all
*@example.com default._domainkey.example.com10.10.20.3 is the efa internal ip
nano /etc/opendkim/TrustedHostsCode: Select all
10.10.20.3
mail.example.com
example.comNow edit POSTFIX configuration file /etc/postfix/main.cf and add following values at the end of file
nano /etc/postfix/main.cfCode: Select all
masquerade_domains = $mydomain
smtpd_milters = inet:localhost:8891, inet:localhost:8893, inet:127.0.0.1:33333
non_smtpd_milters = inet:localhost:8891, inet:localhost:8893
milter_default_action = accept
qmqpd_authorized_clients = 127.0.0.1 [::1]
message_size_limit = 133169152
mailbox_size_limit = 133169152
enable_long_queue_ids = yes
error_notice_recipient = root
sender_canonical_maps = hash:/etc/postfix/sender_canonical
recipient_canonical_maps = hash:/etc/postfix/recipient_canonicalCode: Select all
systemctl start opendkim ; systemctl enable opendkim ; systemctl restart postfixAfter configuring private key in postfix server. there will be another file
cat /etc/opendkim/keys/example.com/default.txt/Code: Select all
default._domainkey IN TXT ( "v=DKIM1; k=rsa; s=email; "
"p=MIGfMA0GCSqGSIb3DQEBAQUAA4GNADCBiQKBgQCdTtEqM8FqndiFYOderzljMMMqBdEp+wJKP+VUbhc9GigmK34ZjrSqqdKjIEWr2q9DvSVp1H1bZs4t050m0HZxJqknDz2yoDJ6W4mCaSCHesRde5V44V/L65Gqm/rvBz1d6CCp8A2515eveWrIAocOD6pKJ4tnXHz3uwV2ZtgQiQIDAQAB" ) ; ----- DKIM key default for example.comCode: Select all
Step 6 – Verify DKIMCode: Select all
mail -vs "Test DKIM" jamerson@gmail.com < /dev/nullCode: Select all
DKIM-Signature: v=1; a=rsa-sha256; c=simple/simple; d=example.com;
s=default.private; t=1402388963;
bh=fdkeB/A0FkbVP2k4J4pNPoe23AvqBm9+b0C3OY87Cw8=;
h=Date:From:Message-Id:To:Subject;
b=M6g0eHe3LNqURha9d73bFWlPfOERXsXxrYtN2qrSQ6/0WXtOxwkEjfoNTHPzoEOlD
i6uLLwV+3/JTs7mFmrkvlA5ZR693sM5gkVgVJmuOsylXSwd3XNfEcGSqFRRIrLhHtbC
mAXMNxJtih9OuVNi96TrFNyUJeHMRvvbo34BzqWY=if you have any questions let us know.
