Uriskip, software
Posted: 17 May 2019 12:25
I devepoped a piece of software, a sample script that create a list of most used 2nd level domains based on latest headers received
most used domains are checked for URIBL one time only and saved into a .cf that is used to skip URIBL check
so these domains most used are skipped and save tons of query , this can solve URIBL blocked problem !
This must be in crontab
# Uriskip, refresh list of excluded domains from uri check
01 02 * * 0 /etc/mail/spamassassin/uriskip.sh
And attached program into spamassassin dir
