Email Details Invisible
Posted: 13 Feb 2019 22:14
by omer
Hello
I've seen e-mails before. All header information seemed. But I haven't seen the details in two days. How can I solve this problem?
Re: Email Details Invisible
Posted: 14 Feb 2019 17:09
by iglooo
You mean message details on mailwatch? It might be this if you're running version 3 -
viewtopic.php?f=13&t=3311
Posted: 14 Feb 2019 17:10
What changed two days ago?
Posted: 14 Feb 2019 17:24
(added the image that was not visible on the first post)
- 6aMJQN.png (110.75 KiB) Viewed 5535 times
Posted: 14 Feb 2019 19:42
by omer
I did the GeoIP database update two days ago.
Posted: 14 Feb 2019 19:49
by omer
I've changed the GeoIP.dat files at this location and it's working right now.
Thank you so much.
/usr/share/GeoIP/GeoIP.dat
/var/www/html/mailscanner/temp/GeoIP.dat
