Block filetype releaseable
Posted: 20 Dec 2018 15:22
by ItemsGmbH
Hi there
Following situation:
We receive tons of mails with .doc attachments containing a virus.
Now we configured our mailscanner to block all .doc files.
Is there a way to make the blocked file releaseable?
Now, if we need a file, we connect via ssh, copy the file & chown it. Then download it via ftp.
It would be great if we could just click at "release" ;)
I´m open for suggestions :-)
Re: Block filetype releaseable
Posted: 22 Dec 2018 23:04
This is very doable, you have to tweak MailScanner and MailWatch though...let me find my notes and post the steps...
Posted: 23 Dec 2018 14:12
# Do you want to store copies of the infected attachments and messages?
Quarantine Infections = yes
define('QUARANTINE_USE_SENDMAIL', false);
Posted: 07 Jan 2019 12:13
by ItemsGmbH
It works. Thanks a lot :D
Is it possible to release the whole mail with the attachment again instead of sending an extra mail with only the attachment?
Posted: 31 Jan 2019 10:32
by ItemsGmbH
*push*
Posted: 31 Jan 2019 12:49
I don't think MailWatch can release a blocked attachment using sendmail.
