Hi!
I accidentally found that some SA rules not working with mails. For example dynrdns rules completely not working.
How I can check what is wrong with all additional rules. KAM and BAYES looks ok.
Spamassassin - some rules not working
Re: Spamassassin - some rules not working
Try running "spamassassin -D --lint". If it gives errors in the end, you can scroll back to see where they are. Most of the time it's a space instead of a tab (in my case ).
