Admin user pw reset does not work
Posted: 11 Oct 2018 18:10
by doggy101
Hi All,
since last yum update I'm not able to login to mailscanner with my admin account.
Even resetting it on the console does not work.
does anyone have any clue?
Re: Admin user pw reset does not work
Posted: 14 Oct 2018 17:37
by doggy101
Resetting it Through webmin also not works :-(
does anyone can point me in the right direction?
Posted: 14 Oct 2018 23:51
Posted: 14 Oct 2018 23:52
You can try resetting it in the database...
Look in /etc/EFA-Config for the mysql root password, log into the database, and alter the users table in mailscanner (mailwatch).
Posted: 01 Nov 2018 19:29
by doggy101
Hi Shawniverson,
found the root password en logged in to the SQL server, in the table "users" there's no user mailwatch to alter.
Posted: 02 Nov 2018 06:47
try this:
mysql
use mailscanner;
select username from users;
What do you get?
