Im currently trying to get this to work in Azure. I've installed a fresh copy. When going through the install it detects that the primary interface has an ip already configured, so i leave the default ip settings / subnet mask and default gateway. Once i get to the end and the install begins it says this ip address is already in use on the interface and stops.
How can i get around this ? as you can't remove an ip address from a NIC on a VM in Azure
