Freash install where is letsencrypt?
MrManor
Post by MrManor »
EDIT: Found it. After update it appeared in the menu!
I am new to EFA so I might miss something obvious, but searching this forum I see posts indicating that letsencrypt support is included since version EFA-3.0.2.5. I just installed the vmware image but dont see any hints on how to install a letsencrypt certificate.
I quite comfortable poking around in a terminal, but if something is already included I would prefer not to setup something which might interfere with future EFA updates.
Regards
Klaus
