MailWatch AD integration not working
andreshko.georgiev
Post by andreshko.georgiev »
Hello guys,
I have a pretty big problem. After upgrading to 3.0.2.5 3 or 4 weeks ago, I just noticed that I cannot log on to MailWatch with AD accounts. It just says "Bad Username or Password". Could you please give me some idea how can I test the link between the MailWatch and the AD? Any clue will be very helpful because right now I am in the middle of nowhere and do not know where or want to check.
Zwabber
Re: MailWatch AD integration not working
Post by Zwabber »
Try to login with "user@yourdomain.name"
Still having issues or need some help still?
andreshko.georgiev
After some research I figured out how to fix the problem. I changed the following lines in /var/www/html/mailscanner/conf.php
from
define('LDAP_USER', 'domain\username');
to
define('LDAP_USER', 'username@domain');
and
this to define('LDAP_USERNAME_FIELD', 'userprincipalname');
and it started to work again. The strangest thing is that is stopped working after the update to 3.0.2.5. Before that it worked fine.
There was some changes made around LDAP in MailWatch. Hopefully they have the issues resolved in the latest builds.
