ow Plugin Update
ow Plugin Update
I updated ow plugin with a workaround, please download and replace ow.pm with this new one if you use it
http://saplugin.16mb.com/
Re: ow Plugin Update
OW plugin give a bonus score to legitimate mail, is very very useful because it learn from email that you send
Used in conjunction to mxpf it can hit near 80% of legitimate incoming emails
a little change to test first external network , this solves internal ipv6 address that give a problem
ipv6 is not supported by plugin
What are you supposed to write in the "ow_message_id_server_prefix" and "ow_recipient_server_prefix" field?
I cant get it to work, It collects some mail from our webservers but put it in wrong tables, but thats all.
/Largo
/Largo
My mailserver is 10.1.1.126 so I write the first part 10.1.
To use ow efa must be the gateway of incoming and outgoing email
Ok, thanks for your reply, I tried that but it didn't work. And of course my EFA is the mailgateway for both incomming and utgoing mail. I have to keep testing.
/Largo
/Largo
can you send me a mail to nicola.piazzi@gruppocomet.it so i send you a reply ?
Nicola,
something weird has happened. I noticed that some of my spam scores were higher than what they are supposed to be
So two of my tables are no longer being populated. I cannot remember what happened on November 14th, but obviously something broke.
I've checked the my version of the plugin against the one from http://saplugin.16mb.com/ and they appear identical.
Do you have any suggestions how I can debug this while the system is running? I'd really like to get some of my spam scores down again.
Any advice on plugin debugging appreciated.
[edit] this is the only change I'm aware of that I made on the 14th: viewtopic.php?f=5&t=2814&p=11155#p11155 which may be completely unrelated.
MariaDB [mailscanner]>
select max(timestamp) from ow_incoming_inreplyto;
select max(timestamp) from ow_outgoing_messageid;
select max(timestamp) from ow_outgoing_recipient;
| max(timestamp) |
| 2018-02-13 16:28:32 |
| 2017-11-14 15:13:07 |
Plugin never changed
I am not able to support you in this, plugin is very self made
You need to see the format of mesaageid from your Exchange if changed
ok, yes that is what is causing my problem.
If I define "trusted_networks" for my intermediate mail hosts, then ow.pm thinks my internal ip is an external host.
Solution? Attempt 1: also add my internal ip of my mail host to trusted ips and let's see what happens.
yes i think you must work on it
Hi Nicola, thanks for replying.
One question regarding om.pm: What is the condition where an entry is added to the ow_incoming_inreplyto table?
That's the only thing left that may have a problem with my configuration.
ow_outgoing_recipient is a table that is filled with email addresses when someone internal send a mail to these
when someone send a message from these email and have spfok from one of these is GOOD
ow_outgoing_messageid if filled when someone internal send email and contain your Exchange generated messageid
when someone fronm external send a mail that have one of these in header is VERY VERY GOOD
and it fill ow_incoming_inreplyto so if someone sent and was referenced in the past is VERY GOOD
Thank you. That explanation will help me resolve what might be another issue I might be having.
