Is it possible to reduce the delay of the greylisting to 1 min instead of the 5 min default?
thanks
Change greylist time
Re: Change greylist time
you can edit /etc/sqlgrey/sqlgrey.conf and tweak for your needs
duesen
## Greylisting delays
# If you want to be really strict (RFC-wise) use these
# This is *not* recommended, you'll have false positives
# reconnect_delay = 15 # don't allow a reconnection before 15 minutes
# max_connect_age = 2 # don't allow a reconnection after 2 hours
# default: (based on real-life experience)
# reconnect_delay = 5
# max_connect_age = 24
duesen
