Hi there,
Is there a possibility to let efa-project send mail from an exchange server, with authentication?
Kind regards,
Justin
Outgoing SMTP
Re: Outgoing SMTP
Yeah you can set up SASL Auth on the Submission port in Postfix...
Re: Outgoing SMTP
Is it also possible to make an authenticated mail relay of EFA? We don't want to open our Exchange server for mail relaying due too securityshawniverson wrote:Yeah you can set up SASL Auth on the Submission port in Postfix...
Re: Outgoing SMTP
I have a question on this topic as well. I have EFA set to filter incoming and outgoing messages to and from my Exchange server. I have a blacklisted IP from Comcast, so I cannot send mail directly to other users. My mail goes through SendGrid, which requires authorization to relay mail, but I saw no option to configure the credentials. Do I need to dive into Postfix conf files to configure this?
Re: Outgoing SMTP
Use Webmin and go to the Postfix mail server. Open "SMTP Authentication And Encryption" and fill in the credentials needed.
