Installation on Xen Server
draven
Post by draven »
Hi Guys
I'm having a real headache. I want to install this brilliant little appliance on one of my customer sites, they however have citrix xen (against my advice) I've got the Vmware version all setup and working at all my other sites it is brilliant.
I've gone to install on xen using the build option in the documentation. I however never seem to get the grub loading screen in which you're supposed to enter the command line, it just seems to boot straight into the centos installer.
Does anyone have a hint or a tip how I can get this to show. It also seems to revert to a no graphical install if that is of an help?
Thanks in advance.
cdburgess75
Re: Installation on Xen Server
Post by cdburgess75 »
I have it running on XenServer. I installed using vmware, then exported. There were also some free tools that can do the job faster (star winds made them), that worked too. Another option is to grab the old centos distort and follow the install section of the wiki to accomplish this.
