Dear readers,
Our max message size is 25MB. If a message exceeds this limit, the sender receives an error message. However, sometimes a message is accepted by EFA, but internally dropped by SPAM filter. In the webportal i see something like "too large". In this rarely case no-one receives a mail; so the sender believes his mail is sent and the receiver doesn't know about anything.
In my opinion, the error is a configuration somewhere in the SPAM check proces: how can i change the max. message size for the spam scanner? Or do you have tips to troubleshoot this problem?
Regards,
Heronimus
SPAM report : too large
Re: SPAM report : too large
In /var/log/messages is see this error line. (Its around that time that mailscanner reports "too large".)
I don't know if this has something to do with it.
Jan 5 12:20:13 mail2 clamd[1460]: lstat() failed on: /var/spool/MailScanner/incoming/25942/1387E12085F.AF86F/tnefwqveiq
I wonder if something else is triggering this problem...
By default MailScanner bypasses spam checking when a message exceeds a certain size (typically 2mb) since most spam is small in size because large spams are costly for spammers. Also, by default, no rules are defined in /etc/MailScanner/rules/max.message.size.rules, so there shouldn't be a limit imposed. Hence the message "too large."
So, do you happen to have a full spam report of a blocked message you can share?
Just to be sure, i examined the config file, it has only 1 rule:Also, by default, no rules are defined in /etc/MailScanner/rules/max.message.size.rules, so there shouldn't be a limit imposed
FromOrTo: default 20480000
In this case, i can't share any details. When it happens again and the message is not sensitive, i will PM you.So, do you happen to have a full spam report of a blocked message you can share?
What do you mean with a full spam report? Where can i get it in EFA?
Regards, Heronimus
Drop that rule or increase it
Same question here, waht exactly do you mean by spam report and where is it hidden?What do you mean with a full spam report? Where can i get it in EFA?
