i'm using EFA since 2-3 weeks, works nice
Is there a way to disable the storing of all the clean emails ?
Actually, our appliances store everything, but i configured only the half of our mail servers, and it use about 2,5Gb every day ...
Thanks to let me know.
Best regards
disable Clean emails store
always fighting spams ...
Re: disable Clean emails store
yes you cananti-spam wrote:Hello,
Best regards
go and edit /etc/MailScanner/MailScanner.conf
search for:
Non Spam Actions = store deliver header "X-Spam-Status:No"
take the 'store' out..
Non Spam Actions = deliver header "X-Spam-Status:No"
run:
service MailScanner restart
Regards,
Zohman.
tooooooo easy ... Why in the hell did i don't think about that ...
Many thanks
Many thanks
EFA-Configure handles this as well.
I really should look at those menu's in more detail, shouldn't I?
Wouldn't it be great if https://efa-project.org/wiki/EFA-Configure_%28menu%29 explains the menu more detailed?
DaN,DaN wrote:Wouldn't it be great if https://efa-project.org/wiki/EFA-Configure_%28menu%29 explains the menu more detailed?
Go for it! This is open source and the wiki is a collaborative!
I know. It's done. https://efa-project.org/wiki/EFA-Configure
