can we block and unblock using subject
suresh
Post by suresh »
are we able to block and unblock using subject?
are we able to release multiple email at the same time?
buzzzo
Re: can we block and unblock using subject
Post by buzzzo »
1) block subject: yes, using mcp
2) yes, see messages operations on webgui
suresh
Post by suresh »
how do i use MCP?
thank you for helping me out.
suresh
Post by suresh »
is MCP more for blocking emails?
if i want to unblock based on subject, what do you recommand?
You could use spamassassin and create a custom rule to assign a strong negative value to an email.
https://wiki.apache.org/spamassassin/WritingRules
suresh
Post by suresh »
Thank you that worked.
file i worked on is /etc/mail/spamassassin/local.cf
and typed
header ALLOWED_RULE_SUBJECT Subject =~ /\btest\b/i
score ALLOWED_RULE__SUBJECT -10
then restarted the MailScanner service.
it seems to be working for me.
