I'm facing the following issue in 3.0.6 (CustomAction.pm version: Version 20140309)
1) mail sended by simple perl script or by telnetting on smtp port is correctly delivered with signature appended
2) mail sended via mail client like thunderbird is delivered without signature.
I've tried the customaction.pm available on github but with it both 1) and 2) produce a Mail delivered without signature.
[UPDATE] On a Mac+Thunderbird the 2) seems to work, does not work on Windows+Thunderbird
Is a know bug ?
Thx
Not always the Outbound Signature is added.
Re: Not always the Outbound Signature is added.
What are your inline signature rules, and is the Thunderbird Client on Windows sending using a from address that matches the signature rules?
P.S. I confirmed the 3.0.0.7-beta version of CustomAction.pm has an issue relating to a whitelisting exception. I have flagged it as an issue.
Mail Clients are configured in the same way.
Is there a way to debug at low level (mailscanner level) the append of the signature ?
thx
thx
Well ok ... i have found the issue (if is it).
On the thunderbird client that expierience the problem I have enabled the enabled the email signing with the s/mime client certificate.
This cause the append on the body of the mail the mime public key, that could be confusing the signing procedure of mailscanner.
Don't know if is a bug or something that could not be fixed.
Thx
Thx
Hmm....definitely something to look into. If the email is being signed using S/MIME, I could see that an inline sig would change the email and therefore break the S/MIME signature...
