Installer suggestion
kommunen
Post by kommunen »
When I tried to configure EFA-3.0.0.1 for the first time I ran into a problem with the installer hanging when it was running freshclam to update the virus database.
The problem turned out to be that dnsmasq hadn't started so freshclam couldn't resolve the address. Therefore I suggest EFA-Init be patched to make sure there's a working DNS before trying to access the network.
The following patch does that and also gives root a possibility to opt-out of the initial config.
<-- snip -->
--- /usr/local/sbin/EFA-Init.org 2014-02-01 22:14:36.786902001 +0100
+++ /usr/local/sbin/EFA-Init 2014-04-28 14:34:00.184767775 +0200
@@ -19,6 +19,13 @@
# along with this program. If not, see <http://www.gnu.org/licenses/>.
+echo -n "Start EFA first-time configure (y/n) -> "
+read StartConf
+if [ ! $StartConf = y ]; then
+ echo Aborting EFA-Init. It can be rerun later using /usr/local/sbin/EFA-Init
+ exit 0
+fi
# Variables
@@ -666,6 +673,9 @@
su postfix -s /bin/bash -c 'razor-admin -register'
sed -i '/^debuglevel/ c\debuglevel = 0' /var/spool/postfix/.razor/razor-agent.conf
+ service dnsmasq start
+ sleep 3
# Update clamav and spamassassin rules
<-- snip -->
Regards,
Peder
Re: Installer suggestion
bbrendon
Post by bbrendon »
Great suggestion. I just installed 3.0.0.1 and am already frustrated. Its stuck doing some freshclam stuff and I can't login. I press alt-f1 to goto another console and it starts the initial configuration process. VERY annoying. Now I have to boot into single user mode and blah blah? Seriously?
I think it should ASK if you want to run the initial setup script. Then I could select the non-default option of no, drop to a shell and do something.
darky83
Site Admin
Post by darky83 »
Feature has been added to the 3.0.0.5 release.
