Hello.
I have some problems with version EFA-3.0.0.4, before updating EFA will work without problems.
My problem now is that the link to release the e-mail has disappeared.
Other problem is that there are no link/signature to report a message as spam
When I receive a spam e-mail in maillog I have this warining:
Calling CustomAction returned Undefined subroutine &MailScanner::CustomConfig::CustomAction called at /usr/lib/MailScanner/MailScanner/Config.pm line 3586.
Sig problems after update
Re: Sig problems after update
I revert to version 3.0.0.2
I checked:
- The message clean have the signature at the end of the message, but if I want to report as a spam I receive an Internal Server Error
- If the message is spam, the notify message has no link to release the message, but in maillog I have no error about Config.pm
Any suggesitons?
Thank you
I checked:
Any suggesitons?
Thank you
When you reverted, was that to a previous snapshot?
Please compare the efa password in...
/etc/EFA-Config
to the one in
/var/www/html/learn-msg.cgi
Are they the same? If not, change it in learn-msg.cgi to match.
/etc/EFA-Config
to the one in
Before do the update I saved the ovf of the virtual machine, so I'm running in parallel the two versions (i use one version or the other changing mx record of domains).
Now I check to download the correct version of CustomAction.pm.
Thank you
Thank you
