Hello
I have started a new thread for a problem I have just discovered and my workaround.
To get the w/b lists working I had to create a domain administrator in the format "name@domain.co.uk" I thought that as a Domain Administrator it would get the quarantine report for the whole domain, I was wrong you only get it for the username.
So now my Domain Admins log in as name@domain.co.uk and a quarantine report is not sent. I then create another domain admin user with the name "domain.co.uk" and choose to send a quarantine report to the other domain admin name@domain.co.uk.
I have done this as when you log in as domain.co.uk you cant use the white/black lists.
So as a summary I create two domain administrators per donain one in the format "name@domain.co.uk" for logging in and managing lists etc. The other is just "domain.co.uk" for sending the domain quarantine report to name@domain.co.uk
I hope this makes sense?
I have also noticed that the quarantine reports are being sent twice even though /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php is set to run at 04:00am I am getting a report earlier at 3:30pm I cant work out why?
Will
Quarantine Reports
Re: Quarantine Reports
What in your /etc/cron.daily, /etc/anacrontab, and root crontab (crontab -l) ?
I have marked the job /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php under scheduled cron jobs in webmin as not active. Thats the one that runs at 4am, I will see what happens tomorrow.
Will
Will
All working fine now, well the reports any way
Just need to figure out how to sort out the multiple domain administrator work around
