EFA-Configure does not save changes.
Posted: 27 Jan 2019 13:53
New issue... just discovered it the other day.
When making changes at the console using the configuration menu, changes are not saved.
For example, drop into the sub-menu "8) Mail Settings" then select "3) Admin Email" and change the address, go back up to the main menu, then drop back in and look, the e-mail address was not changed.
Any suggestions?
Any suggestions?
