[solved] GeoIP not working
Posted: 08 Jan 2019 15:20
by Odon Garma
after update GeoIP Database from tools menu no detail view is possible
GeoIP.dat under /var/www/html/mailscanner/temp is
<html>
<head><title>404 Not Found</title></head>
</html>
/var/log/httpd/ssl_error_log says
PHP Fatal error: GeoIP API: Error traversing database - perhaps it is corrupt? ....
to workaround, to be able to view detail, delete GeoIP.dat!
Any solution for this problem?
Re: GeoIP not working
Posted: 14 Jan 2019 14:40
by Odon Garma
Discontinuation of the GeoLite Legacy Databases
https://blog.maxmind.com/2018/01/02/dis ... databases/
Solutions?? Any??
Someone can send me the latest working GeoIP.dat to replace my non-working version??
Posted: 14 Jan 2019 17:44
eFa v4 is the solution. It uses GeoIP2. I am working hard to get it ready.
Posted: 15 Jan 2019 08:13
I attached the GEOIP files. ( from Dec 17 2018). Since the files are to big to attach, I needed to compress the files a bit.
export GZIP='--best'
tar -c -z -f geoip.tar.gz /root/backup/geoip
Result:
[root@sansspam geoip]# ls -l
total 5492
-rw-r--r-- 1 apache apache 1242574 Dec 17 14:33 GeoIP.dat
-rw-r--r-- 1 root root 1926651 Jan 15 09:06 geoip.tar.gz
-rw-r--r-- 1 apache apache 2447543 Dec 17 14:33 GeoIPv6.dat
P.S.
Any new install or EFA - configure will have the same issue.
January 2, 2019 – The remaining GeoLite Legacy builds will be removed from our website. GeoLite Legacy database users will need to have switched to the GeoLite2 or commercial GeoIP databases and update their integrations.
[root@sansspam ~]# ls -l /usr/share/GeoIP/GeoLiteCountry.dat
lrwxrwxrwx 1 root root 40 Apr 26 2018 /usr/share/GeoIP/GeoLiteCountry.dat -> /var/www/html/mailscanner/temp/GeoIP.dat
Posted: 16 Jan 2019 07:23
by Odon Garma
You made my day! Thanks for the files.
i'm looking forward to start with efa v4
Greetz
Posted: 23 Jan 2019 19:15
by w_bufffet
Thanks, that was helpful.
Posted: 06 Feb 2019 19:59
by iglooo
henk wrote: 15 Jan 2019 08:13
And the file should be a link.
Thanks for the updated database henk! Curious, why does GeoLiteCountry.dat have to be a link? I just extracted your files to /var/www/html/mailscanner/temp/ and it seems to have worked - I can see all the additional details now
Posted: 12 Feb 2019 18:22
Only if you live in the Shire, have proof you are a genuine Hobbit and closely related to Bilbo or Frodo Baggins.
In rare occasions a specific ring will do. In all other cases you need a wizard.
Posted: 28 May 2019 13:06
by DeRaptor
Hey Henk,
also saved my day - after trying 3 different backups
and wondering, what's going on here.
Re: [solved] GeoIP not working
Posted: 26 Sep 2019 21:54
Hi Bonnette,
As you have some funny antivirus protection
Log in to efa and exec:
wget -O geoip.tar.gz https://forum.efa-project.org/download/file.php?id=418
To unpack the downloaded file:
Result:
-rw-r--r-- 1 apache apache 1242574 Dec 17 2018 /root/backup/GeoIP.dat
-rw-r--r-- 1 apache apache 2447543 Dec 17 2018 /root/backup/GeoIPv6.dat
and copy the files to
Posted: 02 Dec 2019 16:06
by teknikl
you're a lifesaver!!
