rep_sa_rule_hits.php no data after sa-update sa-compile
Posted: 05 Jan 2019 19:21
by Alleyviper
Hi there,
After trying to Install custom.cf for SpamAssassin and running
sa-update
sa-compile
The rep_sa_rule_hits.php report shows no data.
Re: rep_sa_rule_hits.php no data after sa-update sa-compile
Posted: 05 Jan 2019 20:38
It would help a lot to post the custom.cf. :shifty:
Run:
spamassassin --lint --debug
Check the config: lines for loaded cf files and, no need to mention, for errors.
This function is also available via the gui, in the Tools and Links menu.
Best quess to solve it quickly, without any assumption(s) on what's wrong: rename it to custom.cf.sav :lol:
If you add new descriptions ( in your cf files) you need to reload the Update SpamAssassin Rule Descriptions via the Tools and Links menu, to make them visible. ( or wait till the next automatic sa-update).
Posted: 07 Jan 2019 13:28
by Alleyviper
Hi Henk,
Thanks for answering back.
I've removed the cf file, done sa-update and sa-compile and performed the descriptions update. No info still.
This is weird, I have two EFA running and on the second One everything works.
=> got hit: "e"
Jan 7 13:30:11.912 [2392] dbg: rules: ran body rule __E_LIKE_LETTER ======> got hit: "e"
Jan 7 13:30:11.913 [2392] dbg: rules: ran body rule __E_LIKE_LETTER ======> got hit: "e"
Jan 7 13:30:11.914 [2392] dbg: rules: ran body rule __E_LIKE_LETTER ======> got hit: "e"
Jan 7 13:30:11.915 [2392] dbg: rules: ran body rule __E_LIKE_LETTER ======> got hit: "e"
Jan 7 13:30:11.916 [2392] dbg: rules: ran body rule __E_LIKE_LETTER ======> got hit: "e"
Jan 7 13:30:11.917 [2392] dbg: rules: ran body rule __E_LIKE_LETTER ======> got hit: "e"
Jan 7 13:30:11.918 [2392] dbg: rules: ran body rule __E_LIKE_LETTER ======> got hit: "e"
Jan 7 13:30:11.919 [2392] dbg: rules: ran body rule __E_LIKE_LETTER ======> got hit: "e"
Jan 7 13:30:11.920 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.921 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.922 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.923 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.924 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.925 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.926 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.927 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.928 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.929 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.930 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.931 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.932 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.933 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.934 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.935 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.936 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.937 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.938 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.939 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.940 [2392] dbg: rules: ran body rule __LOWER_E ======> got hit: "e"
Jan 7 13:30:11.951 [2392] dbg: rules: ran body rule __NONEMPTY_BODY ======> got hit: "I"
Jan 7 13:30:11.975 [2392] dbg: rules: running uri tests; score so far=3.203
Jan 7 13:30:11.979 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 54244 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_0_1
Jan 7 13:30:11.985 [2392] dbg: rules: run_generic_tests - compiling eval code: uri, priority 0
Jan 7 13:30:11.985 [2392] dbg: rules: compiled uri tests
Jan 7 13:30:11.985 [2392] dbg: rules: running body_eval tests; score so far=3.203
Jan 7 13:30:11.988 [2392] dbg: rules: run_eval_tests - compiling eval code: 11, priority 0
Jan 7 13:30:12.012 [2392] dbg: pdfinfo: Identified 0 possible mime parts that need checked for PDF content
Jan 7 13:30:12.012 [2392] dbg: pdfinfo: set_tag called for PDFCOUNT 0
Jan 7 13:30:12.012 [2392] dbg: pdfinfo: set_tag called for PDFIMGCOUNT 0
Jan 7 13:30:12.013 [2392] dbg: https_http_mismatch: anchors 0
Jan 7 13:30:12.013 [2392] dbg: eval: body_length - 1340 - check for min of 256
Jan 7 13:30:12.015 [2392] dbg: eval: body_length - 1340 - check for min of 128
Jan 7 13:30:12.015 [2392] dbg: eval: body_length - 1340 - check for min of 1024
Jan 7 13:30:12.016 [2392] dbg: eval: body_length - 1340 - check for min of 512
Jan 7 13:30:12.019 [2392] dbg: eval: tvd_vertical_words value: 21 / min: 0 / max: 10 - value must be >= min and < max
Jan 7 13:30:12.022 [2392] dbg: rules: running rawbody tests; score so far=3.203
Jan 7 13:30:12.025 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 57706 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_0_1
Jan 7 13:30:12.032 [2392] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority 0
Jan 7 13:30:12.032 [2392] dbg: rules: compiled rawbody tests
Jan 7 13:30:12.036 [2392] dbg: rules: ran rawbody rule __RB_GT_200 ======> got hit: "I need to make this message body somewhat long so TextCat preloads
Jan 7 13:30:12.037 [2392] dbg: rules: [...] I need to make this message body somewhat long so TextCat preloads
Jan 7 13:30:12.037 [2392] dbg: rules: [...] "
Jan 7 13:30:12.041 [2392] dbg: rules: running rawbody_eval tests; score so far=3.203
Jan 7 13:30:12.041 [2392] dbg: rules: run_eval_tests - compiling eval code: 15, priority 0
Jan 7 13:30:12.043 [2392] dbg: rules: running full tests; score so far=3.203
Jan 7 13:30:12.043 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 2604 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_0_1
Jan 7 13:30:12.043 [2392] dbg: rules: run_generic_tests - compiling eval code: full, priority 0
Jan 7 13:30:12.043 [2392] dbg: rules: compiled full tests
Jan 7 13:30:12.044 [2392] dbg: rules-all: running full rule __BASE64_MDAWJan 7 13:30:12.044 [2392] dbg: rules-all: running full rule __RW_BAD_UTF8_3
Jan 7 13:30:12.044 [2392] dbg: rules-all: running full rule NULL_IN_BODY
Jan 7 13:30:12.044 [2392] dbg: rules-all: running full rule __FROM_NAME_IN_MSG
Jan 7 13:30:12.044 [2392] dbg: rules: running full_eval tests; score so far=3.203
Jan 7 13:30:12.044 [2392] dbg: rules: run_eval_tests - compiling eval code: 13, priority 0
Jan 7 13:30:12.044 [2392] dbg: dkim: signature verification disabled, DNS resolving not available
Jan 7 13:30:12.045 [2392] dbg: rules: running meta tests; score so far=3.203
Jan 7 13:30:12.045 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 297 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_0_1
Jan 7 13:30:12.045 [2392] dbg: rules: run_generic_tests - compiling eval code: meta, priority 0
Jan 7 13:30:12.045 [2392] dbg: rules: compiled meta tests
Jan 7 13:30:12.045 [2392] dbg: check: running tests for priority: 10
Jan 7 13:30:12.045 [2392] dbg: rules: running one_line_body tests; score so far=3.203
Jan 7 13:30:12.045 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 513 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_10_1
Jan 7 13:30:12.046 [2392] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority 10
Jan 7 13:30:12.046 [2392] dbg: rules: compiled one_line_body tests
Jan 7 13:30:12.046 [2392] dbg: rules: running head tests; score so far=3.203
Jan 7 13:30:12.046 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 296 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_10_1
Jan 7 13:30:12.046 [2392] dbg: rules: run_generic_tests - compiling eval code: head, priority 10
Jan 7 13:30:12.046 [2392] dbg: rules: compiled head tests
Jan 7 13:30:12.047 [2392] dbg: rules: running body tests; score so far=3.203
Jan 7 13:30:12.047 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 239 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_10_1
Jan 7 13:30:12.047 [2392] dbg: rules: run_generic_tests - compiling eval code: body, priority 10
Jan 7 13:30:12.047 [2392] dbg: rules: compiled body tests
Jan 7 13:30:12.047 [2392] dbg: rules: running uri tests; score so far=3.203
Jan 7 13:30:12.047 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 237 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_10_1
Jan 7 13:30:12.047 [2392] dbg: rules: run_generic_tests - compiling eval code: uri, priority 10
Jan 7 13:30:12.047 [2392] dbg: rules: compiled uri tests
Jan 7 13:30:12.048 [2392] dbg: rules: running rawbody tests; score so far=3.203
Jan 7 13:30:12.048 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 245 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_10_1
Jan 7 13:30:12.048 [2392] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority 10
Jan 7 13:30:12.048 [2392] dbg: rules: compiled rawbody tests
Jan 7 13:30:12.048 [2392] dbg: rules: running full tests; score so far=3.203
Jan 7 13:30:12.048 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 274 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_10_1
Jan 7 13:30:12.048 [2392] dbg: rules: run_generic_tests - compiling eval code: full, priority 10
Jan 7 13:30:12.049 [2392] dbg: rules: compiled full tests
Jan 7 13:30:12.049 [2392] dbg: rules: running full_eval tests; score so far=3.203
Jan 7 13:30:12.049 [2392] dbg: rules: run_eval_tests - compiling eval code: 13, priority 10
Jan 7 13:30:12.049 [2392] dbg: rules: running meta tests; score so far=3.203
Jan 7 13:30:12.049 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 299 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_10_1
Jan 7 13:30:12.049 [2392] dbg: rules: run_generic_tests - compiling eval code: meta, priority 10
Jan 7 13:30:12.050 [2392] dbg: rules: compiled meta tests
Jan 7 13:30:12.050 [2392] dbg: check: running tests for priority: 20
Jan 7 13:30:12.050 [2392] dbg: rules: running one_line_body tests; score so far=3.203
Jan 7 13:30:12.050 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 513 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_20_1
Jan 7 13:30:12.050 [2392] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority 20
Jan 7 13:30:12.050 [2392] dbg: rules: compiled one_line_body tests
Jan 7 13:30:12.051 [2392] dbg: rules: running head tests; score so far=3.203
Jan 7 13:30:12.051 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 296 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_20_1
Jan 7 13:30:12.051 [2392] dbg: rules: run_generic_tests - compiling eval code: head, priority 20
Jan 7 13:30:12.051 [2392] dbg: rules: compiled head tests
Jan 7 13:30:12.051 [2392] dbg: rules: running body tests; score so far=3.203
Jan 7 13:30:12.051 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 239 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_20_1
Jan 7 13:30:12.052 [2392] dbg: rules: run_generic_tests - compiling eval code: body, priority 20
Jan 7 13:30:12.052 [2392] dbg: rules: compiled body tests
Jan 7 13:30:12.052 [2392] dbg: rules: running uri tests; score so far=3.203
Jan 7 13:30:12.052 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 237 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_20_1
Jan 7 13:30:12.052 [2392] dbg: rules: run_generic_tests - compiling eval code: uri, priority 20
Jan 7 13:30:12.052 [2392] dbg: rules: compiled uri tests
Jan 7 13:30:12.052 [2392] dbg: rules: running rawbody tests; score so far=3.203
Jan 7 13:30:12.052 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 245 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_20_1
Jan 7 13:30:12.053 [2392] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority 20
Jan 7 13:30:12.053 [2392] dbg: rules: compiled rawbody tests
Jan 7 13:30:12.053 [2392] dbg: rules: running full tests; score so far=3.203
Jan 7 13:30:12.053 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 274 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_20_1
Jan 7 13:30:12.053 [2392] dbg: rules: run_generic_tests - compiling eval code: full, priority 20
Jan 7 13:30:12.053 [2392] dbg: rules: compiled full tests
Jan 7 13:30:12.053 [2392] dbg: rules: running full_eval tests; score so far=3.203
Jan 7 13:30:12.054 [2392] dbg: rules: run_eval_tests - compiling eval code: 13, priority 20
Jan 7 13:30:12.054 [2392] dbg: rules: running meta tests; score so far=3.203
Jan 7 13:30:12.054 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 299 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_20_1
Jan 7 13:30:12.054 [2392] dbg: rules: run_generic_tests - compiling eval code: meta, priority 20
Jan 7 13:30:12.054 [2392] dbg: rules: compiled meta tests
Jan 7 13:30:12.055 [2392] dbg: check: running tests for priority: 30
Jan 7 13:30:12.055 [2392] dbg: rules: running one_line_body tests; score so far=3.203
Jan 7 13:30:12.055 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 513 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_30_1
Jan 7 13:30:12.055 [2392] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority 30
Jan 7 13:30:12.055 [2392] dbg: rules: compiled one_line_body tests
Jan 7 13:30:12.055 [2392] dbg: rules: running head tests; score so far=3.203
Jan 7 13:30:12.055 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 296 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_30_1
Jan 7 13:30:12.056 [2392] dbg: rules: run_generic_tests - compiling eval code: head, priority 30
Jan 7 13:30:12.056 [2392] dbg: rules: compiled head tests
Jan 7 13:30:12.056 [2392] dbg: rules: running body tests; score so far=3.203
Jan 7 13:30:12.056 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 239 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_30_1
Jan 7 13:30:12.056 [2392] dbg: rules: run_generic_tests - compiling eval code: body, priority 30
Jan 7 13:30:12.056 [2392] dbg: rules: compiled body tests
Jan 7 13:30:12.057 [2392] dbg: rules: running uri tests; score so far=3.203
Jan 7 13:30:12.057 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 237 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_30_1
Jan 7 13:30:12.057 [2392] dbg: rules: run_generic_tests - compiling eval code: uri, priority 30
Jan 7 13:30:12.057 [2392] dbg: rules: compiled uri tests
Jan 7 13:30:12.057 [2392] dbg: rules: running rawbody tests; score so far=3.203
Jan 7 13:30:12.057 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 245 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_30_1
Jan 7 13:30:12.057 [2392] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority 30
Jan 7 13:30:12.058 [2392] dbg: rules: compiled rawbody tests
Jan 7 13:30:12.058 [2392] dbg: rules: running full tests; score so far=3.203
Jan 7 13:30:12.058 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 274 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_30_1
Jan 7 13:30:12.058 [2392] dbg: rules: run_generic_tests - compiling eval code: full, priority 30
Jan 7 13:30:12.058 [2392] dbg: rules: compiled full tests
Jan 7 13:30:12.058 [2392] dbg: rules: running full_eval tests; score so far=3.203
Jan 7 13:30:12.058 [2392] dbg: rules: run_eval_tests - compiling eval code: 13, priority 30
Jan 7 13:30:12.059 [2392] dbg: rules: running meta tests; score so far=3.203
Jan 7 13:30:12.059 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 299 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_30_1
Jan 7 13:30:12.059 [2392] dbg: rules: run_generic_tests - compiling eval code: meta, priority 30
Jan 7 13:30:12.059 [2392] dbg: rules: compiled meta tests
Jan 7 13:30:12.059 [2392] dbg: check: running tests for priority: 500
Jan 7 13:30:12.059 [2392] dbg: dns: harvest_dnsbl_queries
Jan 7 13:30:12.060 [2392] dbg: rules: running one_line_body tests; score so far=3.203
Jan 7 13:30:12.060 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 516 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_500_1
Jan 7 13:30:12.060 [2392] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority 500
Jan 7 13:30:12.060 [2392] dbg: rules: compiled one_line_body tests
Jan 7 13:30:12.060 [2392] dbg: rules: running head tests; score so far=3.203
Jan 7 13:30:12.060 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 298 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_500_1Jan 7 13:30:12.061 [2392] dbg: rules: run_generic_tests - compiling eval code: head, priority 500
Jan 7 13:30:12.061 [2392] dbg: rules: compiled head tests
Jan 7 13:30:12.061 [2392] dbg: rules: running body tests; score so far=3.203
Jan 7 13:30:12.061 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 241 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_500_1Jan 7 13:30:12.061 [2392] dbg: rules: run_generic_tests - compiling eval code: body, priority 500
Jan 7 13:30:12.061 [2392] dbg: rules: compiled body tests
Jan 7 13:30:12.062 [2392] dbg: rules: running uri tests; score so far=3.203
Jan 7 13:30:12.062 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 239 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_500_1
Jan 7 13:30:12.062 [2392] dbg: rules: run_generic_tests - compiling eval code: uri, priority 500
Jan 7 13:30:12.062 [2392] dbg: rules: compiled uri tests
Jan 7 13:30:12.062 [2392] dbg: rules: running rawbody tests; score so far=3.203
Jan 7 13:30:12.062 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 247 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_500_1
Jan 7 13:30:12.063 [2392] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority 500
Jan 7 13:30:12.063 [2392] dbg: rules: compiled rawbody tests
Jan 7 13:30:12.063 [2392] dbg: rules: running full tests; score so far=3.203
Jan 7 13:30:12.063 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 276 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_500_1Jan 7 13:30:12.063 [2392] dbg: rules: run_generic_tests - compiling eval code: full, priority 500
Jan 7 13:30:12.063 [2392] dbg: rules: compiled full tests
Jan 7 13:30:12.063 [2392] dbg: rules: running meta tests; score so far=3.203
Jan 7 13:30:12.064 [2392] info: rules: meta test KAM_VOICEMAIL has dependency 'KAM_RAPTOR' with a zero score
Jan 7 13:30:12.064 [2392] info: rules: meta test KAM_BBB has dependency 'KAM_RAPTOR' with a zero score
Jan 7 13:30:12.065 [2392] info: rules: meta test KAM_INSURE2 has dependency 'CBJ_GiveMeABreak' with a zero score
Jan 7 13:30:12.066 [2392] dbg: rules: meta test KAM_CREDIT2 has undefined dependency '__KAM_URIBL_PCCC'
Jan 7 13:30:12.067 [2392] dbg: rules: meta test MULTI_FORGED has undefined dependency 'FORGED_GMAIL_RCVD'
Jan 7 13:30:12.068 [2392] dbg: rules: meta test KAM_SALE has undefined dependency 'BODY_8BITS'
Jan 7 13:30:12.072 [2392] info: rules: meta test KAM_JURY has dependency 'KAM_RAPTOR' with a zero score
Jan 7 13:30:12.074 [2392] info: rules: meta test KAM_CARD has dependency 'KAM_RPTR_SUSPECT' with a zero score
Jan 7 13:30:12.076 [2392] info: rules: meta test KAM_FAKE_DELIVER has dependency 'KAM_RAPTOR' with a zero score
Jan 7 13:30:12.076 [2392] dbg: rules: meta test KAM_BAD_DNSWL has undefined dependency 'IN_BRBL'
Jan 7 13:30:12.076 [2392] dbg: rules: meta test KAM_BAD_DNSWL has undefined dependency 'RCVD_IN_BRBL_RELAY'
Jan 7 13:30:12.076 [2392] dbg: rules: meta test KAM_BAD_DNSWL has undefined dependency '__KAM_URIBL_PCCC'
Jan 7 13:30:12.076 [2392] dbg: rules: meta test KAM_BAD_DNSWL has undefined dependency 'KAM_MESSAGE_EMAILBL_PCCC'
Jan 7 13:30:12.076 [2392] dbg: rules: meta test KAM_BAD_DNSWL has undefined dependency 'RCVD_IN_HOSTKARMA_W'
Jan 7 13:30:12.077 [2392] info: rules: meta test KAM_FORGED_ATTACHED has dependency 'KAM_RAPTOR' with a zero score
Jan 7 13:30:12.077 [2392] dbg: rules: meta test KAM_GRABBAG9 has undefined dependency 'MALFORMED_FREEMAIL'
Jan 7 13:30:12.079 [2392] dbg: rules: meta test CONFIRMED_FORGED has undefined dependency 'FORGED_GMAIL_RCVD'
Jan 7 13:30:12.079 [2392] info: rules: meta test KAM_WARRANTY has dependency 'CBJ_GiveMeABreak' with a zero score
Jan 7 13:30:12.080 [2392] info: rules: meta test KAM_BADPDF2 has dependency 'KAM_RPTR_SUSPECT' with a zero score
Jan 7 13:30:12.084 [2392] info: rules: meta test KAM_PAYPAL2 has dependency 'KAM_RAPTOR' with a zero score
Jan 7 13:30:12.087 [2392] info: rules: meta test KAM_AMAZON has dependency 'KAM_RAPTOR' with a zero score
Jan 7 13:30:12.090 [2392] info: rules: meta test JMQ_CONGRAT has dependency 'KAM_RAPTOR' with a zero score
Jan 7 13:30:12.090 [2392] dbg: rules: meta test JMQ_CONGRAT has undefined dependency 'HK_SPAMMY_FILENAME'
Jan 7 13:30:12.090 [2392] dbg: rules: meta test KAM_GOOGLE2 has undefined dependency 'HK_SPAMMY_FILENAME'
Jan 7 13:30:12.091 [2392] info: rules: meta test KAM_EVICTION has dependency 'KAM_RAPTOR' with a zero score
Jan 7 13:30:12.091 [2392] info: rules: meta test KAM_REALLY_FAKE_DELIVER has dependency 'KAM_RPTR_PASSED' with a zero score
Jan 7 13:30:12.092 [2392] info: rules: meta test KAM_INSURE has dependency 'CBJ_GiveMeABreak' with a zero score
Jan 7 13:30:12.092 [2392] info: rules: meta test KAM_AUTO has dependency 'CBJ_GiveMeABreak' with a zero score
Jan 7 13:30:12.093 [2392] info: rules: meta test KAM_PHISHY_DOLLARS has dependency 'KAM_RAPTOR' with a zero score
Jan 7 13:30:12.096 [2392] info: rules: meta test KAM_NOTIFY2 has dependency 'KAM_IFRAME' with a zero score
Jan 7 13:30:12.103 [2392] dbg: rules: meta test KAM_COLLEGE has undefined dependency '__KAM_URIBL_PCCC'
Jan 7 13:30:12.106 [2392] dbg: rules: meta test KAM_PHISH2 has undefined dependency '__KAM_URIBL_PCCC'
Jan 7 13:30:12.107 [2392] info: rules: meta test KAM_WARRANTY3 has dependency 'CBJ_GiveMeABreak' with a zero score
Jan 7 13:30:12.113 [2392] dbg: rules: flush_evalstr (add_evalstr) compiling 60266 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_500_1
Jan 7 13:30:12.121 [2392] dbg: rules: flush_evalstr (add_evalstr) compiling 60069 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_500_2
Jan 7 13:30:12.131 [2392] dbg: rules: flush_evalstr (add_evalstr) compiling 60062 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_500_3
Jan 7 13:30:12.141 [2392] dbg: rules: flush_evalstr (add_evalstr) compiling 60125 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_500_4
Jan 7 13:30:12.150 [2392] dbg: rules: flush_evalstr (add_evalstr) compiling 60240 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_500_5
Jan 7 13:30:12.159 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 10296 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_500_6
Jan 7 13:30:12.161 [2392] dbg: rules: run_generic_tests - compiling eval code: meta, priority 500
Jan 7 13:30:12.161 [2392] dbg: rules: compiled meta tests
Jan 7 13:30:12.165 [2392] dbg: check: running tests for priority: 1000
Jan 7 13:30:12.165 [2392] dbg: rules: running one_line_body tests; score so far=5.002
Jan 7 13:30:12.165 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 519 chars of Mail::SpamAssassin::Plugin::Check::_one_line_body_tests_1000_1
Jan 7 13:30:12.166 [2392] dbg: rules: run_generic_tests - compiling eval code: one_line_body, priority 1000
Jan 7 13:30:12.166 [2392] dbg: rules: compiled one_line_body tests
Jan 7 13:30:12.166 [2392] dbg: rules: running head tests; score so far=5.002
Jan 7 13:30:12.166 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 300 chars of Mail::SpamAssassin::Plugin::Check::_head_tests_1000_1
Jan 7 13:30:12.166 [2392] dbg: rules: run_generic_tests - compiling eval code: head, priority 1000
Jan 7 13:30:12.166 [2392] dbg: rules: compiled head tests
Jan 7 13:30:12.167 [2392] dbg: rules: running head_eval tests; score so far=5.002
Jan 7 13:30:12.167 [2392] dbg: rules: run_eval_tests - compiling eval code: 9, priority 1000
Jan 7 13:30:12.167 [2392] dbg: rules: running body tests; score so far=5.002
Jan 7 13:30:12.168 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 243 chars of Mail::SpamAssassin::Plugin::Check::_body_tests_1000_1
Jan 7 13:30:12.168 [2392] dbg: rules: run_generic_tests - compiling eval code: body, priority 1000
Jan 7 13:30:12.168 [2392] dbg: rules: compiled body tests
Jan 7 13:30:12.168 [2392] dbg: rules: running uri tests; score so far=5.002
Jan 7 13:30:12.168 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 241 chars of Mail::SpamAssassin::Plugin::Check::_uri_tests_1000_1Jan 7 13:30:12.168 [2392] dbg: rules: run_generic_tests - compiling eval code: uri, priority 1000
Jan 7 13:30:12.168 [2392] dbg: rules: compiled uri tests
Jan 7 13:30:12.169 [2392] dbg: rules: running body_eval tests; score so far=5.002
Jan 7 13:30:12.169 [2392] dbg: rules: run_eval_tests - compiling eval code: 11, priority 1000
Jan 7 13:30:12.170 [2392] dbg: PLG-ImageCerberus: : ImageCerberus_check :: Rule: ImageCerberusPLG4 (0.90, 1.20)
Jan 7 13:30:12.170 [2392] dbg: PLG-ImageCerberus: : ImageCerberus_check :: path: /etc/spamassassin/imageCerberus
Jan 7 13:30:12.170 [2392] dbg: PLG-ImageCerberus: : ImageCerberus_check :: maximgsize: 100
Jan 7 13:30:12.170 [2392] dbg: PLG-ImageCerberus: : ImageCerberus_processingMsg:: Begin image's scores estimation
Jan 7 13:30:12.170 [2392] dbg: PLG-ImageCerberus: : imageTextExtractionFromMSG:: 0 images extracted
Jan 7 13:30:12.170 [2392] dbg: PLG-ImageCerberus: : ImageCerberus_check:: Write Mail Header
Jan 7 13:30:12.170 [2392] dbg: check: tagrun - tag PLGIMAGECERBERUSOUT is now ready, value: 0.0 (No images found)
Jan 7 13:30:12.170 [2392] dbg: PLG-ImageCerberus: : ImageCerberus_check :: Rule: ImageCerberusPLG5 (1.20, 100.0)
Jan 7 13:30:12.170 [2392] dbg: PLG-ImageCerberus: : ImageCerberus_check :: Rule: ImageCerberusPLG1 (0.00, 0.30)
Jan 7 13:30:12.170 [2392] dbg: PLG-ImageCerberus: : ImageCerberus_check :: Rule: ImageCerberusPLG3 (0.60, 0.90)
Jan 7 13:30:12.170 [2392] dbg: PLG-ImageCerberus: : ImageCerberus_check :: Rule: ImageCerberusPLG2 (0.30, 0.60)
Jan 7 13:30:12.170 [2392] dbg: rules: running rawbody tests; score so far=5.002
Jan 7 13:30:12.170 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 249 chars of Mail::SpamAssassin::Plugin::Check::_rawbody_tests_1000_1
Jan 7 13:30:12.171 [2392] dbg: rules: run_generic_tests - compiling eval code: rawbody, priority 1000
Jan 7 13:30:12.171 [2392] dbg: rules: compiled rawbody tests
Jan 7 13:30:12.171 [2392] dbg: rules: running full tests; score so far=5.002
Jan 7 13:30:12.171 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 278 chars of Mail::SpamAssassin::Plugin::Check::_full_tests_1000_1
Jan 7 13:30:12.171 [2392] dbg: rules: run_generic_tests - compiling eval code: full, priority 1000
Jan 7 13:30:12.171 [2392] dbg: rules: compiled full tests
Jan 7 13:30:12.172 [2392] dbg: rules: running meta tests; score so far=5.002
Jan 7 13:30:12.172 [2392] dbg: rules: flush_evalstr (run_generic_tests) compiling 303 chars of Mail::SpamAssassin::Plugin::Check::_meta_tests_1000_1
Jan 7 13:30:12.172 [2392] dbg: rules: run_generic_tests - compiling eval code: meta, priority 1000
Jan 7 13:30:12.172 [2392] dbg: rules: compiled meta tests
Jan 7 13:30:12.172 [2392] dbg: plugin: Mail::SpamAssassin::Plugin::DCC=HASH(0x4a3eba8) implements 'check_post_learn', priority 0
Jan 7 13:30:12.173 [2392] dbg: dcc: DCC learning not enabled by dcc_learn_score
Jan 7 13:30:12.173 [2392] dbg: check: is spam? score=5.002 required=5
Jan 7 13:30:12.173 [2392] dbg: check: tests=BAYES_50,MISSING_DATE,MISSING_HEADERS,NO_RECEIVED,NO_RELAYS
Jan 7 13:30:12.173 [2392] dbg: check: subtests=__BODY_TEXT_LINE,__EMPTY_BODY,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__E_LIKE_LETTER,__GATED_THROUGH_RCVD_REMOVER,__HAS_FROM,__HAS_MESSAGE_ID,__HAS_MSGID,__HAS_SUBJECT,__KAM_DROPBOX2,__KAM_FAKEDELIVER12,__KAM_FAKEDELIVER4,__KAM_FAKEDELIVER6,__KAM_FAKEDELIVER8,__KAM_GOOGLE2_2,__KAM_HARP3,__KAM_HAS_0_URIS,__KAM_JURY3,__KAM_MAILSPLOIT2,__KAM_MULTIPLE_FROM,__KAM_PAYPAL3B,__KAM_UPS2,__KAM_WU1,__KHOP_NO_FULL_NAME,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__LOWER_E,__MISSING_REF,__MISSING_REPLY,__MSGID_OK_DIGITS,__MSGID_OK_HOST,__MSOE_MID_WRONG_CASE,__NONEMPTY_BODY,__NOT_SPOOFED,__RB_GT_200,__SANE_MSGID,__SUBJECT_EMPTY,__SUBJ_SHORT,__TO_NO_ARROWS_R,__UNUSABLE_MSGID
Jan 7 13:30:12.174 [2392] dbg: timing: total 2519 ms - init: 1889 (75.0%), b_tie_ro: 17 (0.7%), parse: 1.09 (0.0%), extract_message_metadata: 2.3 (0.1%), get_uri_detail_list: 2.3 (0.1%), tests_pri_-1000: 9 (0.4%), compile_gen: 193 (7.7%), compile_eval: 33 (1.3%), tests_pri_-950: 7 (0.3%), tests_pri_-900: 7 (0.3%), tests_pri_-90: 24 (1.0%), check_bayes: 15 (0.6%), b_tokenize: 4.1 (0.2%), b_tok_get_all: 1.88 (0.1%), b_comp_prob: 0.24 (0.0%), b_tok_touch_all: 4.5 (0.2%), b_finish: 2.5 (0.1%), tests_pri_0: 441 (17.5%), check_spf: 0.14 (0.0%), tests_pri_10: 4.6 (0.2%), tests_pri_20: 4.8 (0.2%), tests_pri_30: 4.6 (0.2%), tests_pri_500: 106 (4.2%), tests_pri_1000: 7 (0.3%)
Posted: 07 Jan 2019 21:16
If you run on the other EFA machine, you don't have the same output?
Compair the to EFA configs and look in the logfiles to find the difference(s).
To disable the duplicate messages ( disable the test), you can add, somewhere at the top, in
meta __E_LIKE_LETTER  (0)
meta __LOWER_E  (0)
Now run run spamassassin --lint --debug again.
The source of this:
/var/lib/spamassassin/3.004001/updates_spamassassin_org/72_active.cf
##{ MIXED_ES if can(Mail::SpamAssassin::Conf::feature_bug6558_free) ifplugin Mail::SpamAssassin::Plugin::ReplaceTags
meta MIXED_ES ( ! HTML_IMAGE_ONLY_16 ) && ( __LOWER_E > 20 ) && ( __E_LIKE_LETTER > ( (__LOWER_E * 14 ) / 10) ) && ( __E_LIKE_LETTER < ( 10 * __LOWER_E ) )
describe MIXED_ES Too many es are not es
tflags MIXED_ES publish
endif
endif
##} MIXED_ES if can(Mail::SpamAssassin::Conf::feature_bug6558_free) ifplugin Mail::SpamAssassin::Plugin::ReplaceTags
Posted: 08 Jan 2019 02:12
by Alleyviper
Hi Henk,
Everything got worse. Now mailgraph stopped generating graphs.
I Did not understand the last part of your answer. It is to add that part to updates_spamassassin_org/72_active.cf file?
Size 211 KB
Status
EXPAND VIEW TOPIC REVIEW: REP_SA_RULE_HITS.PHP NO DATA AFTER SA-UPDATE SA-COMPILE
by henk ยป 07 Jan 2019 21:16
CODE: SELECT ALL
CODE: SELECT ALL
CODE: SELECT ALL
meta __LOWER_E (0)
The source of this:
CODE: SELECT ALL
endif
endif
Posted: 08 Jan 2019 11:10
The last part is just to mention the cause of the looping messages, that's all
The solution, as mentioned, is to disable the specific test, by setting in /etc/mail/spamassassin/local.cf:
meta __LOWER_E (0)
As logs are our best friends, use them to find errors.
Posted: 08 Jan 2019 12:57
by Alleyviper
Hi Henk,
Not working. Still no data on report and magraph is not generating logs.
Posted: 08 Jan 2019 21:48
by Alleyviper
Hi Henk,
Going to
cat /var/log/httpd/ssl_error_log | grep error
I have the following error:
PHP Parse error: syntax error, unexpected '}', expecting end of file in /var/www/html/mailscanner/rep_sa_rule_hits.php on line 52
<?php
* MailWatch for MailScanner
* Copyright (C) 2003-2011 Steve Freegard (steve@freegard.name)
* Copyright (C) 2011 Garrod Alwood (garrod.alwood@lorodoes.com)
* Copyright (C) 2014-2017 MailWatch Team (https://github.com/mailwatch/1.2.0/graphs/contributors)
* This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public
* License as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later
* version.
* This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied
* warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
* In addition, as a special exception, the copyright holder gives permission to link the code of this program with
* those files in the PEAR library that are licensed under the PHP License (or with modified versions of those files
* that use the same license as those files), and distribute linked combinations including the two.
* You must obey the GNU General Public License in all respects for all of the code used other than those files in the
* PEAR library that are licensed under the PHP License. If you modify this program, you may extend this exception to
* your version of the program, but you are not obligated to do so.
* If you do not wish to do so, delete this exception statement from your version.
* You should have received a copy of the GNU General Public License along with this program; if not, write to the Free
* Software Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
// Include of necessary functions
require_once __DIR__ . '/filter.inc.php';
require_once __DIR__ . '/functions.php';
// Authentication checking
require __DIR__ . '/login.function.php';
// add the header information such as the logo, search, menu, ....
$filter = html_start(__('sarulehits37'), 0, false, true);
$sql = '
SELECT
spamreport,
isspam
FROM
maillog
WHERE
spamreport IS NOT NULL
AND spamreport != ""
' . $filter->CreateSQL();
$result = dbquery($sql);
if (!$result->num_rows > 0) {
die(__('diemysql99') . "\n");
Line 52 ends with "}" Symbol
Tried to do some changes but with no effect.
Posted: 08 Jan 2019 22:18
The fast solution is to copy the file from the second efa machine, and replace it on the first one. Assuming that's the only file changed. :oops:
Posted: 09 Jan 2019 00:36
by Alleyviper
Hi Henk,
## The mailgraph issue is resolved (it was stopped):
/etc/init.d/mailgraph-init start
## The rep_sa_rule_hits.php is still with problems
- Files between MX and MX1 are the same.
I Will investigate this issue.
Posted: 10 Jan 2019 00:24
by Alleyviper
This is weird.
EFA 3.0.2.6
No Change made on rep_sa_rule_hits.php
A) Checked file and copied the same on mx2 I have.
B) ]# php -l rep_sa_rule_hits.php No syntax errors detected in rep_sa_rule_hits.php
Posted: 10 Jan 2019 10:01
Weird? Welcome to IT :whistle:
As you mentioned mailgraph was stopped, did you stop it, or did it fail to start at boot?
Did php -l on the original rep_sa_score_dist.php show errors?
Do you use webmin? Consider (read switch) to use SSH to access EFA (or any other Linux machine)
How do you compare the files? Sure hope you use diff to compare, as visual compair is mission impossible due various reasons.
To get a quick view on modified files (date/time), just run on both EFA's
ls -l /var/www/html/mailscanner
Posted: 10 Jan 2019 18:42
by Alleyviper
Hi Henk,
No errors on other files PHP.
I use webmin only to check Database queries.
Listed both mx and files on mailscanner are the same
Mailgraph didn't boot, i had to start it manually
