my mailscanner configuration blocks emails with correct file attachments with the extension "filename.BS4PRJ".
The rule triggered is:
MailScanner: Dangerous attachment according to Microsoft Q883260 (filename.PST) .
There is no attachment with an extension ".pst" in these emails.
I added the "allow \.BS4PRJ$ - -" to filename.rules.conf but that doesnt help.
I removed the "deny \.pst$ - - " from filename.rules.conf but event that doesnt help.
What is wrong here?
Mailscanner blocks attachment with extension .BS4PRJ
Re: Mailscanner blocks attachment with extension .BS4PRJ
Is BS4PRJ an archive?
This is not an archive. It is a database of an cad application.
I changed the archive rules too.
I can reproduce this behavior/problem with a simple txt file renamed to that extension and send to efa as attachment.
I cannot confirm this. An attachment with the extension BS4PRJ passes right through my installation.
Can you run the following commands and post the results here?
cd /etc/Mailscanner/
grep -r -i "Q883260" .
Ok,
i rechecked the syntax of the pst deny and there was a tipo in there.
It is working now.
Thank you!
It is working now.
Thank you!
