update 3.0.2.5 - > 3.0.2.6
Posted: 03 Jan 2018 10:45
I just updated efa from 3.0.2.5 - > 3.0.2.6. No issues in de update process.
However I noticed a minor change.
1. the MailScanner service is renamed to mailscanner. ( all lowercase) checking the service will still return the MailScanner name
I changed this in /usr/sbin/EFA-Monitor-cron
2. The first was complaining
So I removed it and run it again
3. Run
and see if you can compile without errors
[root@sansspam log]# service mailscanner status
MailScanner is running under process id 2718
# Configurable Variables
MaxRestartAttempts=3
# Monitored Service Array (daemon=sysv)
MonitoredServices=("mysqld=mysqld" "MailScanner=mailscanner" "master=postfix" "httpd=httpd" "clamd=clamd" "unbound=unbound" "saslauthd=saslauthd" "dccifd=adcc")
# Enable restart expiry (1 day)
RestartExpiry=1
freshclam -v
Detected duplicate databases /var/lib/clamav/daily.cld and /var/lib/clamav/daily.cvd. The /var/lib/clamav/daily.cld database is older and will not be loaded, you should manually remove it from the database directory
rm /var/lib/clamav/daily.cld
sa-update -v
sa-compile
