3.0.2.5 update failed - hyper-v problem!
Posted: 05 Dec 2017 08:41
Hey there,
I'm trying to update to 3.0.2.5 but I always getting an error on the hyper-v part:
[EFA] Good you are root
[EFA] Starting update to EFA-3.0.2.5
Setting up Update Process
* EFA: dl7.efa-project.org
* base: mirror.infonline.de
* epel: mir01.syntis.net
* extras: centos.mirror.iphh.net
* mariadb: mirror.netcologne.de
* updates: centos.mirror.iphh.net
http://centos.mirror.iphh.net/CentOS/6. ... repomd.xml: [Errno 12] Timeout on http://centos.mirror.iphh.net/CentOS/6. ... repomd.xml: (28, 'Operation too slow. Less than 1 bytes/sec transfered the last 30 seconds')
Trying other mirror.
http://centos.mirror.iphh.net/CentOS/6. ... repomd.xml: [Errno 14] PYCURL ERROR 7 - "Failed to connect to 2001:868:0:182::13: Network is unreachable"
Resolving Dependencies
--> Running transaction check
---> Package kernel.x86_64 0:2.6.32-696.16.1.el6 will be installed
---> Package kernel-devel.x86_64 0:2.6.32-696.16.1.el6 will be installed
---> Package kernel-firmware.noarch 0:2.6.32-696.10.3.el6 will be updated
---> Package kernel-firmware.noarch 0:2.6.32-696.16.1.el6 will be an update
---> Package kernel-headers.x86_64 0:2.6.32-696.10.3.el6 will be updated
---> Package kernel-headers.x86_64 0:2.6.32-696.16.1.el6 will be an update
---> Package kernel.x86_64 0:2.6.32-642.15.1.el6 will be erased
--> Processing Dependency: kernel < 2.6.32-643 for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(__vmbus_driver_register) = 0xb1b6bc8c for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(vmbus_close) = 0x9751d826 for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(vmbus_driver_unregister) = 0xd15637a5 for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(vmbus_open) = 0xddc5c776 for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(vmbus_recvpacket_raw) = 0x4cd23ff4 for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
--> Processing Dependency: kernel(vmbus_sendpacket) = 0x60267c8f for package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
---> Package kernel-devel.x86_64 0:2.6.32-642.15.1.el6 will be erased
---> Package kmod-microsoft-hyper-v.x86_64 0:4.1.2-20160809 will be erased
--> Processing Dependency: microsoft-hyper-v-kmod = 4.1.2 for package: microsoft-hyper-v-4.1.2-20160809.x86_64
---> Package microsoft-hyper-v.x86_64 0:4.1.2-20160809 will be erased
Error: Package: kmod-microsoft-hyper-v-4.1.2-20160809.x86_64 (installed)
Requires: kernel < 2.6.32-643
Removing: kernel-2.6.32-642.15.1.el6.x86_64 (@updates)
kernel = 2.6.32-642.15.1.el6
Installed: kernel-2.6.32-696.1.1.el6.x86_64 (@updates)
kernel = 2.6.32-696.1.1.el6
Installed: kernel-2.6.32-696.3.1.el6.x86_64 (@updates)
kernel = 2.6.32-696.3.1.el6
Installed: kernel-2.6.32-696.3.2.el6.x86_64 (@updates)
kernel = 2.6.32-696.3.2.el6
Installed: kernel-2.6.32-696.10.3.el6.x86_64 (@updates)
kernel = 2.6.32-696.10.3.el6
Available: kernel-2.6.32-696.el6.x86_64 (base)
kernel = 2.6.32-696.el6
Available: kernel-2.6.32-696.6.3.el6.x86_64 (updates)
kernel = 2.6.32-696.6.3.el6
Available: kernel-2.6.32-696.10.1.el6.x86_64 (updates)
kernel = 2.6.32-696.10.1.el6
Available: kernel-2.6.32-696.10.2.el6.x86_64 (updates)
kernel = 2.6.32-696.10.2.el6
Available: kernel-2.6.32-696.13.2.el6.x86_64 (updates)
kernel = 2.6.32-696.13.2.el6
Installing: kernel-2.6.32-696.16.1.el6.x86_64 (updates)
kernel = 2.6.32-696.16.1.el6
Available: kernel-debug-2.6.32-696.el6.x86_64 (base)
Available: kernel-debug-2.6.32-696.1.1.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.3.1.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.3.2.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.6.3.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.10.1.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.10.2.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.10.3.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.13.2.el6.x86_64 (updates)
Available: kernel-debug-2.6.32-696.16.1.el6.x86_64 (updates)
** Found 1 pre-existing rpmdb problem(s), 'yum check' output follows:
kmod-microsoft-hyper-v-4.2.3.1-20171101.x86_64 is a duplicate with kmod-microsoft-hyper-v-4.1.2-20160809.x86_64
sendmail: warning: /etc/postfix/main.cf, line 764: overriding earlier entry: smtpd_client_restrictions=permit_sasl_authenticated, reject_rbl_client sbl.spamhaus.org, reject_rbl_client cbl.abuseat.org, reject_rbl_client all.spam-rbl.fr, reject_rbl_client bl.spamcop.net, reject_rbl_client relays.mail-abuse.org, reject_rbl_client sbl-xbl.spamhaus.org, reject_rbl_client zen.spamhaus.org, reject_rbl_client b.barracudacentral.org
postdrop: warning: /etc/postfix/main.cf, line 764: overriding earlier entry: smtpd_client_restrictions=permit_sasl_authenticated, reject_rbl_client sbl.spamhaus.org, reject_rbl_client cbl.abuseat.org, reject_rbl_client all.spam-rbl.fr, reject_rbl_client bl.spamcop.net, reject_rbl_client relays.mail-abuse.org, reject_rbl_client sbl-xbl.spamhaus.org, reject_rbl_client zen.spamhaus.org, reject_rbl_client b.barracudacentral.org
Update to Version 3.0.2.4 FAILED. Updates cancelled.
The question is, can i exclude this part from been checkt because I updated the Linux Integration Service for hyper-v already to 4.2.x so I don't want to downgrade that again.
Thanks for every helpful answer.
best regars
best regars
