No Mailwatch after upgrade 2.3-2.4
sharktech
Post by sharktech »
Hi All
Just thought i would share an issue. upgraded to 3.0.2.4 from 2.3 and i was getting connection refused to mailwatch.
logged into webmin and apache hadn't started due to the following :
Starting httpd: Syntax error on line 6 of /etc/httpd/conf.d/mod_security.conf:
Invalid command 'SecRuleRemoveById', perhaps misspelled or defined by a module not included in the server configuration
[FAILED]
Disabled Modsecurity in EFA-Configure and re-enabled and all works fine.
Re: No Mailwatch after upgrade 2.3-2.4
You have some entries in the wrong place in mod_security.conf
Look in the first if block and remove all references to "SecRuleRemoveById"
