new 3.0.2.3 install - Cannot login to Mailwatch admin page with any acct if change to use AD/LDAP
VMguru
Post by VMguru »
I'd been using EFA for a couple of years now successfully upgrading and using Active Directory for authentication in MailWatch to view quarantined emails, release them, etc.
Well the last upgrade crashed out to the point I decided to download and install from scratch the latest VMware OVA of eFa to replace the old one.
I went through and made all the same changes to the config.php as before from: viewtopic.php?f=14&t=1484.
Made changes to mailwatch_ldap_sync.sh that I found in the new path of /usr/local/bin/mailwatch/tools/LDAP/ to match.
Made sure I installed php-ldap (yum install php-ldap)
Made sure I installed the openldap-clients (yum install openldap-clients)
I ran the script above and my database populated properly.
But when I make the last change to conf.php of
define('USE_LDAP', true);
I can no longer login to the main MailWatch page with the root account or another I created that is the main user, both defined as Administrators in the MySQL database. I cannot login as any of my AD users either.
I receive:
Forbidden
You don't have permission to access /mailscanner/checklogin.php on this server.
Additionally, a 403 Forbidden error was encountered while trying to use the ErrorDocument to handle the request.
If I change the setting back to
define('USE_LDAP', false);
then I can successfully login with only the root and original or accts I create and none of the AD/LDAP accounts that were imported.
For those I get:
Bad Username or Password
Any ideas?
Thanks, Jeff
Re: new 3.0.2.3 install - Cannot login to Mailwatch admin page with any acct if change to use AD/LDAP
Please do the following:
1) What error message are you getting in /var/log/httpd logs when you see the forbidden message?
2) Try turning off mod_security in EFA-Configure. 11) Apache Settings --> 2) Modsecurity
VMguru
Post by VMguru »
Since I hate log files :roll: , I did the 2nd step, Disabled Modsecurity. I then set LDAP to true & both local and AD accounts now work, thank you! :D
At which version did that setting get added?
This time around, I finally found the setting in config.php that allows you to aggregate all the email addresses in Exchange bound to a single account so they are included together in one quarantine report,
//Set QUARANTINE_FILTERS_COMBINED to true to combine quarantine report into a single report when user filters are present
define('QUARANTINE_FILTERS_COMBINED', true);
that is brilliant!!!
Thank you again for all the work you all do with this appliance!
Jeff
VMguru
Post by VMguru »
BTW, here is what the last entry in modsec_audit.log says before I disabled modsecurity in Apache:
--7f0db94b-A--
[13/Jun/2017:07:36:49 --0400] WT-OUQoAACMAAHD5BfgAAAAD 84.201.133.68 58331 10.0.0.35 443
--7f0db94b-B--
GET /robots.txt HTTP/1.1
Host: <my EFA>
Connection: Keep-Alive
user-agent: Mozilla/5.0 (compatible; YandexBot/3.0; +http://yandex.com/bots)
--7f0db94b-F--
HTTP/1.1 403 Forbidden
Content-Length: 212
Connection: close
Content-Type: text/html; charset=iso-8859-1
--7f0db94b-E--
--7f0db94b-H--
Message: Access denied with code 403 (phase 2). Operator EQ matched 0 at REQUEST_HEADERS. [file "/etc/httpd/modsecurity.d/activated_rules/modsecurity_crs_21_protocol_anomalies.conf"] [line "47"] [id "960015"] [rev "1"] [msg "Request Missing an Accept Header"] [severity "NOTICE"] [ver "OWASP_CRS/2.2.6"] [maturity "9"] [accuracy "9"] [tag "OWASP_CRS/PROTOCOL_VIOLATION/MISSING_HEADER_ACCEPT"] [tag "WASCTC/WASC-21"] [tag "OWASP_TOP_10/A7"] [tag "PCI/6.5.10"]
Action: Intercepted (phase 2)
Stopwatch: 1497353809998308 1092 (- - -)
Stopwatch2: 1497353809998308 1092; combined=291, p1=208, p2=60, p3=0, p4=0, p5=23, sr=42, sw=0, l=0, gc=0
Response-Body-Transformed: Dechunked
Producer: ModSecurity for Apache/2.7.3 (http://www.modsecurity.org/); OWASP_CRS/2.2.6.
Server: Apache
Engine-Mode: "ENABLED"
--7f0db94b-Z--
increased security or increased convenience, never both.
*sigh*
Indeed. My preference is to not have modsecurity around, or at least disabled by default. The problem is that any string can trigger a false positive, as long as it resembles an "attack." Not effective, in my opinion. MailWatch has beefed up its security and has tested its code against OWASP. I am fine with that.
