				EFA don't block dangerous file attachment.
				Posted: 20 Apr 2017 03:51
				by buonleloi
I had added some file extension to /etc/MailScanner/filename.rules.conf
But seem they didn't work.
Use test from
http://www.emailsecuritycheck.net
4/7 can reach my inbox
				Re: EFA don't block dangerous file attachment.
				Posted: 20 Apr 2017 21:38
				Restarted MailScanner?
				Posted: 21 Apr 2017 10:33
				by buonleloi
				Yes, restart many time.
				Posted: 24 Apr 2017 23:13
				Did you send a dll yourself or from this site?
They may be obfuscating the file somehow, is the reason I ask...
				Posted: 25 Apr 2017 06:06
				test 4/7 attaches a batch file called "attached%2E" which decodes to "attached."  That file cannot be run unless it is renamed to "attached.bat", so I would ignore that one.
test 5/7 attaches a batch file called "ATT00001.dll" and should be blocked, so I'd consider this a legitimate fail.
test 6/7 attaches a batch file called "attached.()bat".  The extension ".()bat" won't run on a windows computer, so I wouldn't consider that a fail.  You can ignore this.
test 7/7 attaches a batch file called "attached"  As it has no extension, Windows won't run it.  Not a legitimate fail.  Ignore.
				Posted: 25 Apr 2017 06:17
				edited /etc/MailScanner/filename.rules.conf and added (you need to change the spaces to tabs which are not preserved here):
# Deny dll's
140 deny    \.dll$          Windows DLL          Dll's not allowed.
restarted mailscanner, and sent myself the dll attachment.
Result? blocked, so everything is good and in working order.
				Posted: 29 Aug 2020 06:58
				by omer
I try as you suggest. But since I restarted the MailScanner service it gives an error like this.
[root@gw omer]# nano /etc/MailScanner/filename.rules.conf
[root@gw omer]# /etc/init.d/mailscanner restart
Restarting MailScanner ...
Possible syntax error on line 140 of /etc/MailScanner/filename.rules.conf at /usr/share/MailScanner/perl/MailScanner/Config.pm line 1672
Remember to separate fields with tab characters! at /usr/share/MailScanner/perl/MailScanner/Config.pm line 1674
MailScanner restarted with process id 14923
				Posted: 30 Aug 2020 11:23
				You have a typo, and it is telling you where the typo is.
