Hi!
I'm unable to login with my AD credentials in MailScanner after upgrading EFA to version 3.0.2.1.
I have double checked /var/www/html/mailscanner/conf.php and it's untuched, so AD login should work as of prior to upgrade EFA.
Nothing in the /var/log/httpd/error.log log file.
Any idéas?
Unable to login with AD after upgrade to 3.0.2.1
Re: Unable to login with AD after upgrade to 3.0.2.1
I solved it my self.
I had to edit 'LDAP_USERNAME_FIELD in MailWatch conf.php.
Changed
to
Not sure why it worked before.
Changed
define('LDAP_USERNAME_FIELD', 'cn');
define('LDAP_USERNAME_FIELD', 'mail');
