Recent Messages not showing since 3.0.1.9
Posted: 28 Mar 2017 06:50
by colin
Since upgrading to 3.0.1.9, I am no longer seeing messages in "Recent Messages" or "Message Listing" report. The last message in the list is " Restart needed to update to 3.0.1.6" Other than that, everything appears to be working ok.
Re: Recent Messages not showing since 3.0.1.9
Posted: 28 Mar 2017 10:02
So you see that message, but nothing else?
Posted: 28 Mar 2017 10:35
by colin
Yes Shawn, that message and all messages prior to it but none since the update.
Posted: 28 Mar 2017 13:30
If you restart MailScanner, are you seeing any error messages?
Posted: 28 Mar 2017 14:17
by colin
[root@mailprotect ~]# service MailScanner restart
Restarting MailScanner ...
MailScanner restarted with process id 20742
Posted: 28 Mar 2017 14:21
That is good. Has whole system been restarted since upgrade?
Posted: 28 Mar 2017 14:22
by colin
Mar 28 15:17:20 mailprotect postfix/anvil[14094]: statistics: max connection rate 1/60s for (smtp:91.200.12.164) at Mar 28 15:09:30
Mar 28 15:17:20 mailprotect postfix/anvil[14094]: statistics: max connection count 1 for (smtp:91.200.12.164) at Mar 28 15:09:30
Mar 28 15:17:20 mailprotect postfix/anvil[14094]: statistics: max cache size 2 at Mar 28 15:12:53
Mar 28 15:18:06 mailprotect postfix/qmgr[26372]: 5B6CA6009C: from=<
root@australia.local>, size=935, nrcpt=1 (queue active)
Mar 28 15:18:06 mailprotect postfix/trivial-rewrite[20775]: warning: database /etc/postfix/virtual.db is older than source file /etc/postfix/virtual
Mar 28 15:18:06 mailprotect postfix/qmgr[26372]: C343A6009F: from=<>, size=3330, nrcpt=1 (queue active)
Mar 28 15:18:06 mailprotect postfix/smtp[20776]: connect to australia.local[172.24.2.3]:25: Connection refused
Mar 28 15:18:06 mailprotect postfix/smtp[20777]: connect to australia.local[172.24.2.3]:25: Connection refused
Mar 28 15:18:06 mailprotect postfix/smtp[20777]: C343A6009F: to=<
root@australia.local>, relay=none, delay=223114, delays=223114/0.05/0/0, dsn=4.4.1, status=deferred (connect to australia.local[172.24.2.3]:25: Connection refused)
Mar 28 15:18:06 mailprotect postfix/smtp[20776]: 5B6CA6009C: to=<
root@australia.local>, orig_to=<root>, relay=none, delay=55084, delays=55083/0.26/0.01/0, dsn=4.4.1, status=deferred (connect to australia.local[172.24.2.3]:25: Connection refused)
Mar 28 15:18:15 mailprotect postfix/smtpd[20780]: warning: database /etc/postfix/virtual.db is older than source file /etc/postfix/virtual
Mar 28 15:18:15 mailprotect postfix/smtpd[20780]: warning: database /etc/postfix/relay_recipients.db is older than source file /etc/postfix/relay_recipients
Mar 28 15:18:15 mailprotect postfix/smtpd[20780]: warning: database /etc/postfix/recipient_access.db is older than source file /etc/postfix/recipient_access
Mar 28 15:18:15 mailprotect postfix/smtpd[20780]: warning: hostname no-reverse-dns-configured.com does not resolve to address 80.82.78.188
Mar 28 15:18:15 mailprotect postfix/smtpd[20780]: connect from unknown[80.82.78.188]
Mar 28 15:18:15 mailprotect postfix/smtpd[20780]: warning: unknown[80.82.78.188]: SASL LOGIN authentication failed: authentication failure
Mar 28 15:18:15 mailprotect postfix/smtpd[20780]: disconnect from unknown[80.82.78.188] ehlo=1 auth=0/1 rset=1 quit=1 commands=3/4
Mar 28 15:19:14 mailprotect postfix/smtpd[20780]: connect from scz-181-114-97-00059.wimaxtigo.bo[181.114.97.59]
Mar 28 15:19:15 mailprotect postfix/smtpd[20780]: warning: scz-181-114-97-00059.wimaxtigo.bo[181.114.97.59]: SASL LOGIN authentication failed: authentication failure
Mar 28 15:19:15 mailprotect postfix/smtpd[20780]: disconnect from scz-181-114-97-00059.wimaxtigo.bo[181.114.97.59] helo=1 auth=0/1 quit=1 commands=2/3
Posted: 28 Mar 2017 14:24
I see a deferred message and a failed SASL connection attempt, but nothing else in that log entry.
Posted: 28 Mar 2017 14:29
by colin
I rebooted the whole system again just to be sure, but it is no different.
Are there any logs worth looking at?
Posted: 28 Mar 2017 14:32
I would follow the maillog and make sure you are accepting and relaying mail, for starters.
Posted: 28 Mar 2017 14:40
by colin
Not sure if I made it clear but I am receiving emails ok, it's that they are not appearing in the list. The email header is showing that it is routed through EFA.
Posted: 28 Mar 2017 14:56
by colin
I ran logwatch and found this:
Could not use Custom Function code MailScanner::CustomConfig::InitMailWatchLogging, it could not be "eval"ed. Make sure the module is correct with perl -wc (Error: DBD::mysql::st execute failed: Unknown column 'rblspamreport' in 'field list' at /usr/share/MailScanner/perl/custom/MailWatch.pm line 189, <CLIENT> line 81.: 1 Time(s)
Does that help?
Posted: 28 Mar 2017 14:58
by colin
Contents of MailWatch.pm around that line number is:
# Log message
$sth->execute(
$$message{timestamp},
$$message{id},
$$message{size},
$$message{from},
$$message{from_domain},
$$message{to},
$$message{to_domain},
$$message{subject},
$$message{clientip},
$$message{archiveplaces},
$$message{isspam},
$$message{ishigh},
$$message{issaspam},
$$message{isrblspam},
$$message{spamwhitelisted},
$$message{spamblacklisted},
$$message{sascore},
$$message{spamreport},
$$message{virusinfected},
$$message{nameinfected},
$$message{otherinfected},
$$message{reports},
$$message{ismcp},
$$message{ishighmcp},
$$message{issamcp},
$$message{mcpwhitelisted},
$$message{mcpblacklisted},
$$message{mcpsascore},
$$message{mcpreport},
$$message{hostname},
$$message{date},
$$message{"time"},
$$message{headers},
$$message{quarantined},
$$message{rblspamreport},
$$message{token});
Posted: 28 Mar 2017 15:04
Ahh ok you are missing a column.
Run this:
wget https://raw.githubusercontent.com/mailwatch/1.2.0/develop/upgrade.php
sudo /usr/bin/php ./upgrade.php
Posted: 28 Mar 2017 15:08
by colin
Thanks Shawn, that has done the trick.
Re: Recent Messages not showing since 3.0.2.3
Posted: 02 Jun 2017 13:23
by BharatPagi
I've manually installed EFA mailscanner and setup a domain, but somehow I cannot see any emails in recent messages.
The version of EFA is 3.0.2.3.
Can anyone help me on this.
Bharat
Posted: 03 Jun 2017 10:02
Check your MAILWATCH_HOME variable in /var/www/html/mailscanner/conf.php. It may be pointing to /opt... instead of /var...
Posted: 05 Jun 2017 06:58
by BharatPagi
Hi Shawn,
Thank you very much as it's working like charm.
Bharat.
Posted: 11 Oct 2017 09:25
by stuarthurst
shawniverson wrote: ↑28 Mar 2017 15:04
Run this:
Just done my update also and had the same issue - this also fixed mine. Thanks
Stuart
