Upgrade 3.0.1.4 -> 3.0.1.8 failed
urmet
Post by urmet »
Hello.
Upgrading from 3.0.14 got this message:
What is solution?
Br,
Urmet
Re: Upgrade 3.0.1.4 -> 3.0.1.8 failed
urmet
Post by urmet »
Hello.
I've tried to do second step:
yum check-update ca-certificates; (($?==100)) && yum update ca-certificates || yum reinstall ca-certificates
But then this error:
Could not retrieve mirrorlist https://dl.efa-project.org/rpm/mirrors-efa error was
14: PYCURL ERROR 77 - "Problem with the SSL CA cert (path? access rights?)"
Error: Cannot retrieve metalink for repository: epel. Please verify its path and try again
Setting up Reinstall Process
You may need to disable some repositories temporarily as you work on your ca-certificate issue.
Take a look in /etc/yum.repos.d and disable the affected repos temporarily by setting enabled=0 for them.
When your issue is fixed, be sure to set them back to enabled=1.
urmet
Post by urmet »
Thank you.
Disabling repositories temporarily worked.
Now I can upgrade EFA.
stuarthurst
Post by stuarthurst »
Thanks +1
This fixed mine too as it hadn't been able to upgrade since 3.0.1.7
Just upgrading it now to 3.0.1.9 and on-wards.
