Hi all
I had an issue with mail stuck in mailqueue after upgrade to 3009, after searching through the log I eventually found the issue to be one line in my main.cf file
The upgrade had appended the meta_directory - etc/postfix/ to the same line as the last entry and not on its own line.
fixed the above and all works fine now
Mail Stuck in MailQueue - Fixed (For Me)
Re: Mail Stuck in MailQueue - Fixed (For Me)
I had a similar problem. Here's a link to the message thread that fixed it for me:
viewtopic.php?f=5&t=1490
