Quarantine Reports for Whole Domains
G3 Support
Post by G3 Support »
I have an issue where a user before the upgrade used to get a daily report for 3 domains that they receive email on.
Now when you run the cron job it says no items are detected but if you look there are quite a few. If you remove the domain name from the filters list and add an individuals email address that you know has quarantined email and re run the task it works fine.
Why can I now not suddenly get entire domain quarantine reports?
Matt
Re: Quarantine Reports for Whole Domains
I'm guessing that the code has changed for the quarantine_reports.php in mailwatch.
So, if I add a domain to the user filter, it should report on the whole domain? I will test this out and see what is happening.
