I have starterd the upgrade from 3.0.0.6 to 3.0.0.7 all run ok.
Next after the reboot I have started the upgrade from 3.0.0.7 to 3.0.0.8 but it freeze when excute this process:
Appending installation info to /usr/lib64/perl5/perllocal.pod
Encoding-FixLatin-1.04
Encoding-FixLatin-1.04/README
Encoding-FixLatin-1.04/Changes
Encoding-FixLatin-1.04/LICENSE
Encoding-FixLatin-1.04/dist.ini
Encoding-FixLatin-1.04/META.yml
Encoding-FixLatin-1.04/MANIFEST
Encoding-FixLatin-1.04/META.json
Encoding-FixLatin-1.04/Makefile.PL
Encoding-FixLatin-1.04/t
Encoding-FixLatin-1.04/t/00-basics.t
Encoding-FixLatin-1.04/bin
Encoding-FixLatin-1.04/bin/fix_latin
Encoding-FixLatin-1.04/t/10-fix_latin.t
Encoding-FixLatin-1.04/t/20-bytes_only.t
Encoding-FixLatin-1.04/t/30-xs-optional.t
Encoding-FixLatin-1.04/t/release-pod-syntax.t
Encoding-FixLatin-1.04/lib/Encoding
Encoding-FixLatin-1.04/lib/Encoding/FixLatin.pm
Encoding-FixLatin-1.04/t/release-pod-coverage.t
Writing Makefile for Encoding::FixLatin
Skip blib/lib/Encoding/FixLatin.pm (unchanged)
cp bin/fix_latin blib/script/fix_latin
/usr/bin/perl -MExtUtils::MY -e 'MY->fixin(shift)' -- blib/script/fix_latin
Manifying blib/man1/fix_latin.1
Manifying blib/man3/Encoding::FixLatin.3pm
It freeze more than one hour I have stopped the update and interruped and restart but with same result, the update freeze
how can solve ? restore the system to 3.0.0.6 ?
Best regards
Enrico
Best
Update from EFA 3.0.0.7 to 3.0.0.8 freeze
Re: Update from EFA 3.0.0.7 to 3.0.0.8 freeze
Interesting.
How does everything look otherwise?
The next command in the update is the following:
What happens when you try to run this yourself (use sudo)?
mysql --user=mailwatch --password=$(grep MAILWATCHSQLPWD /etc/EFA-Config | sed 's/MAILWATCHSQLPWD://') \
--database=mailscanner < /usr/local/bin/mailwatch/tools/UTF8_Database/upgrade_mysql_db_to_utf8.sql
I have the same issue, did you found any solution?
Running this command hangs forever too :
If you do ctrl + c you get:
ERROR 1034 (HY000) at line 6: 137 when fixing table
Regards Chris
Regards Chris
Are you sure it is frozen? Larger databases take longer to convert.
